Old 06-05-2008, 11:35 PM   #1
Husker
Husker's Avatar
Anyone running a Weiand Intake..
With a QJet?
I am considering a Weiand 8004 Action Plus Intake or an Edelbrock 2101 Performer instead of the cast Iron stock for a little better performance and hopefully mileage. Are they essentially the same type Manifold?
Anyhelp would be helpfull.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-06-2008, 12:45 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Anyone running a Weiand Intake..
You should get a little more performance out of either, but in my experience, I doubt you'll see a mileage increase. Bigger plenums and runners typically use more fuel.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-06-2008, 08:02 AM   #3
caminokid
Chevy nut
caminokid's Avatar
This will be the only time I will have to disagree with you man! I had a complete performer package on my 350 I had in my 77 SS El Camino. Cam, intake and carb. I also had Hooker super comps and duals with glass packs. I was able to go 311 miles on 3/4 of a tank. Before I swapped everything out....I was lucky to go 200 miles on a full tank. I guess doing a full package and tuning everything right you can get mileage. Now I dont know if I could do the same with one of our trucks...but you should be able to get a little better mileage.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-06-2008, 09:58 AM   #4
pumpkin
pumpkin's Avatar
I have never noticed any power or economy benifits from just an aluminium manifold change. The two manifolds your talking about are basicaly just coppies of a stock chevy manifold. They will give a bit more power at rpms over 2500rpm, but not realy noticeable in the seat of your pants. When you change cam, manifold and carb, its more likely the cam that gives you more economy and power. An aliminium manifold did give me better cold drivabilty, and alow me to have the choke come off sooner. For better economy with just a manifold change you can rejet the carb and play around with the adjustable power valve in a Q jet.
pumpkin is offline   Reply With Quote
Old 06-06-2008, 01:55 PM   #5
fnoblitt
fnoblitt's Avatar
i choose the weiand over the edlebrock , i like the looks of the weiand better.
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 06-06-2008, 03:10 PM   #6
68Stepbed
68Stepbed's Avatar
I had a Weiand 8004 once and I liked it alot. I generally like the look of the Performer better, but I think the Weiand makes better torque. As far as better performance, i've always noticed more with aluminum intakes over stock.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-06-2008, 07:27 PM   #7
67_C-30
67_C-30's Avatar
Don't hesitate to disagree with me. I sometimes argue with myself! I just remember years ago when I was a young'un, I bought a new Holley 600 for my Z28 and the gas mileage sucked. Everyone told me the adapter plate I had on the Q jet manifold was why my mileage dropped so much. So I bought a Performer intake and it didn't make any difference whatsoever. So in my side by side comparsion experience, the Q jet manifold with an adapter got the same mileage as the Performer. I later put a new Q jet on it, and it got about the same as it did with the worn out Q jet. It did perform much better, but I believe it had more to do with the carb than the intake alone. I may be wrong, but I don't believe the intake will hurt mileage much (if any), but I don't believe just the intake alone will help it either.
My trucks
Old 06-06-2008, 07:56 PM   #8
caminokid
Chevy nut
caminokid's Avatar
See there was the problem! You bought the Holley. Which when we was younger I dont think we had the option of buying a Edelbrock carb. I agree on the intake alone wont help. Having the whole package that is matched together...then it will save mileage.
Old 06-06-2008, 09:40 PM   #9
67_C-30
67_C-30's Avatar
Speak for yourself Pops*(-j/k! )! The Edelbrock EPS and "new" Carter AFB's were back on the market when I was cuttin my teeth on hot rods!
*Please don't refuse to sell me that bumper now!!
My trucks
Old 06-06-2008, 10:27 PM   #10
Pont406
caminokid, did you remove the cat at the same time?
Pont406 is offline   Reply With Quote
Old 06-06-2008, 11:03 PM   #11
caminokid
Chevy nut
caminokid's Avatar
I had duals on it. When I got it the motor trans and exhaust was gone. I dont believe in cats.
Old 06-06-2008, 11:05 PM   #12
caminokid
Chevy nut
caminokid's Avatar
I remember the Carter AFB...that was a hell of a good carb! I have been hot rodding since 82. He calls me POPS.
