Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-06-2008, 12:59 PM   #801
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Thanks guys This is my first "real" exhaust system install. I cobbled together the previous system before and after shortening, but it was no where near this quality; just good enough to get it on the road with no leaks.
lyriks, this is why I chose not to flip the TA tabs on the xmember like the ECE and CCP versions come (ECE is reversible; bolt-on, CCP is not). I do have a step notch and I will be attempting to run pipes all the way back
Frizzle Fry is offline   Reply With Quote
Old 06-06-2008, 01:02 PM   #802
lyrikz
PITbut
lyrikz's Avatar
Well, thats the route im gonna go.. Following you. ahaha.. Since i dont have a cab or a bed on the truck, im going to do my own exhaust... Should be fun fun...
You didnt bend your own pipes, did you just buy sections of prebent and then made yours???
lyrikz is offline   Reply With Quote
Old 06-06-2008, 04:59 PM   #803
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I was able to adjust it so the indicator is dead on in all gears. Plus as an added bonus, there's a whole lot less play now. Gotta rebuild the column to get it perfect...[/QUOTE]
Well Frizzle you sold me. After about two hours of trying to modify the old bracket after I swapped out my th350 with a 700R4 I went and bought the linkage. I hope to have it in on Monday. yeah.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-06-2008, 05:07 PM   #804
Hart_Rod
Hart_Rod's Avatar
Mike,
Do you plan on running an X-Pipe?
Hart_Rod is offline   Reply With Quote
Old 06-06-2008, 08:54 PM   #805
ChevyDude
Mike I used the same Lokar linkage on my 71'...it works great!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 06-06-2008, 11:51 PM   #806
Frizzle Fry
Originally Posted by Hart_Rod View Post
Mike,
If you can come up with where to put one without hanging below the frame
No that's been ruled out. The plan is to run a crossover right in front of the tranny xmember.
Old 06-06-2008, 11:52 PM   #807
Frizzle Fry
I like it; simple. Makes you wonder why the factory felt in necessary to run that big ol' conglomeration...
Old 06-07-2008, 12:06 AM   #808
Hart_Rod
Hart_Rod's Avatar
I see what you mean. A bolt in crossover in front of the transmission mount should work well.
Old 06-07-2008, 12:51 PM   #809
Frizzle Fry
Good call
Flowmaster U-Fit 3"
Although I'm going to have to get two more of the S-bends made at a local shop (they don't sell them individually).
Old 06-07-2008, 01:33 PM   #810
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Not sure if this helps, but DR Gas sells them individually from what I have found..
http://drgas.com/development/category.php?cid=4
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-08-2008, 02:46 PM   #811
Frizzle Fry
Thanks for the link. I also found this place: http://www.mandrelbendingsolutions.c...let/StoreFront
Old 06-09-2008, 11:10 PM   #812
gringoloco
A guy with a truck
gringoloco's Avatar
...I'm going to have to get two more of the S-bends made at a local shop (they don't sell them individually).
Did you try contacting Flowmaster directly? Each piece of that kit has an individual part number. I mention this only because I had a similar situation with Summit/Flowmaster before.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-12-2008, 08:02 PM   #813
Sinisterspeed
Sinisterspeed's Avatar
Insane! One of the best step by steps I have ever thumbed.. errr Clicked through. I'll have to keep my eye open and see it on the road sometime.
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 06-12-2008, 10:21 PM   #814
Frizzle Fry
Thanks man. Have you seen this?
Gringo, yes I did think of that. Didn't call them yet though
Old 06-27-2008, 06:17 PM   #815
Frizzle Fry
Well, I took a chance on a local shop hoping the bends wouldn't be too bad They're not usable IMO (mandrel is the only way to go). So there's $60 gone and a lesson learned.
I contacted Flowmaster directly today. They said they would have to make them for me at the end of a 3" run, but got back to me with a quote of $24.44 each. I said I'll take em
This, and some other distractions including the 64, has derailed my progress on Tubby for a couple weeks. So with this new wind in my sails I'm headed out to work on the passenger side now I should have both sides hung to the mufflers by the time I get these.
Old 07-06-2008, 12:24 AM   #816
VA72C10
VA72C10
VA72C10's Avatar
Absolutely awesome work and an inspiration for me to get moving on mine
Old 07-12-2008, 12:44 AM   #817
'72 Chevy Suburban
Chevy's Rock!
'72 Chevy Suburban's Avatar
Incredible build FF... You are certainly a master of fabrication. I just wish that I could make a decent looking weld! Keep up the great work and I look forward to following along.
John
'59 NAPCO Pickup
'70 K10 Pickup 350
'72 C20 Suburban 350 (MIA)
'57 Chieftain 455
'68 Firebird Convertible - 400
'68 Catalina Convertible - 400
'85 Vette
'72 Chevy Suburban is offline   Reply With Quote
Old 07-15-2008, 12:50 AM   #818
Dinos63
chevy only
Dinos63's Avatar
mike , nice work, dig your new shop also
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-15-2008, 04:58 AM   #819
Frizzle Fry
Thanks guys. I've been trying not to post on this thread until I have a significant update. You should be seeing one this weekend
Old 07-15-2008, 07:31 PM   #820
lownfast
Gettinlow & Goinfast
i wish i had that much clearance under my k5... i had to go with 2.25 pipe to fit. it was a sad day....
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 07-15-2008, 08:29 PM   #821
abadsvt
abadsvt's Avatar
About time! We have been sitting at our computers waiting for some new updates for the last couple weeks.
Keep up the great work!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 07-18-2008, 06:10 AM   #822
Frizzle Fry
Time for some more pics.
The exhaust is all mocked up. I just need to pull it out and finish some of the welds, then hit it with some anti-corrosion coating and reinstall. The rear-most hangers also need to be installed, but it's 95% done.
I got ambitious during the install and decided to run it all the way to the back. Good thing I have an over-sized notch (I knew I kept it full size for a reason )
I achieved my goal which was to keep it all above the main frame rails. The exception is in the very rear where it's still tucked up nicely and is above the lower portion of the fuel tank and higher than the lower body line. The only thing visible from the side is the tips of the turndowns
I did open a big 'ol can of worms with this. Quite a few changes were/are required to make this work, but it'll be worth it. Fuel and brake line relocation, airlines need to be relocated (was going to switch to hard line anyway), Stock panhard bar mount on the pumpkin had to be removed/ground, and the biggest one being the rear shocks require a reconfig yet again. That's OK because I have another reason to do that as well that I'll show later.
...on to the pics!
First the money shots, then the details:
Old 07-18-2008, 06:18 AM   #823
Frizzle Fry
Cleaned up the pumpkin a little:
Shocks will mount under the bridge instead of behind it:
Old 07-18-2008, 06:19 AM   #824
Frizzle Fry
Old 07-18-2008, 06:28 AM   #825
Frizzle Fry
...and the other reason I want to relocate the rear shocks; I'll be running two rows of Buddy Buckets.
The second row will be just the two buckets and no center seat. That's the arrangement that fits perfectly between the rear tubs. Like this:
...and the reason to move the shocks (left one is up on seat tracks):
