Old 06-07-2008, 04:37 AM   #1
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: 1969 Chevy Stepside Restoration/Build up
This is an update of what I have done to it since I first got it...
After I removed the old 250 straight six and granny gear 4 speed manual. They are going to be replaced with a 350 engine and a 700R4 4 speed automatic transmission.
New sheet metal to replace the rusted/missing and automatic floor hump welded in to replace the large manual one.
I converted it over from manual steering to power. It bolts in perfect but the bumper bracket doesn't fit (it hits the pump) so I have to modify the bumper bracket slightly.
The step side fender is finished with the body work. The fender was completely warped all down the top so it took a lot of bondo to shape it back to its original shape.
Started working on the door and I found that it had a very "thick" paint job. There is a ton of bondo build up on it and they bondoed over random holes like the factory mirror holes and other ones. I welded up the holes except for the mirror ones and ground them down. Now for tommarow more paint removal and bondo the dents on the door.
matthew20061 is offline   Reply With Quote
