Old 06-07-2008, 12:14 PM   #1
eedgell
It's the air up here
eedgell's Avatar
Broken exhaust stud in BB
I broke a exhaust stud the other day on the drivers side collector of my 454 BB. I thought about drilling the stud for an easy out, then heating the collector to cherry red, and then turning out. Good idea or bad? Any other thoughts?
eedgell is offline   Reply With Quote
Old 06-07-2008, 12:19 PM   #2
chevys2die4
Junior Member
chevys2die4's Avatar
Re: Broken exhaust stud in BB
I broke 2 off of my BB last week! No Fun, I broke 2 drill bits and my easy out, I found its just as easy to drill all the way through wit a smaller bit then just undersize and run a tap through. Just my 2 cents. I feel your pain!!!
68 SB 396
72 SB CHEYENNE 402
04 Silverado SS
chevys2die4 is offline   Reply With Quote
Old 06-07-2008, 01:18 PM   #3
HoupPhotography
Generall, if the bolt broke from tightening the easy out WILL NOT WORK. THe best way is to drill the stud out and tap it. The trick is not to drill the entire bolt out use a smaller radious bit than the broken stud and tap it, so you can try to keep the same size bolts.
Note; if you drill the stud and use an easy out and it breaks off, it will turn into a headache and send you out searching for carbide bits. Do it the easier way way and save yorself some f-bombs.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 06-07-2008, 02:01 PM   #4
eedgell
eedgell's Avatar
I broke the bolt trying to replace the donut. I agree that breaking an easy out off in there would be the first F-bomb. When re-tapping how hard is it to match the lines of the old threads? You cant just cut new ones, right?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
Old 06-07-2008, 02:38 PM   #5
airdale94
airdale94's Avatar
If the manifold is cast iron, you can you a cutting torch if you're careful. Use low setting and several sessions. The cast iron generally won't melt like the steel. Then run a tap through it. I've done this with success on heads.
airdale94 is offline   Reply With Quote
