Converting 2WD cab to 4WD
Ok guys I have a question. Does anyone have any tips on putting a 2WD cab on a 4WD frame. I heard something about the 2 1/4" spacers for the back of the cab. I also know about putting the large 4WD hump in the 2WD cab. The hole has not been cut in the 2WD cab. Also I heard I will also need to do more work to the floor to make it fit.
Any ideas, suggestions, gripes, or criticism of any kind is welcomed. Thanks Guys Hey does anyone have a pic of a 4WD floor without the carpet and stuff??? Last edited by 76PasoGMC; 06-07-2008 at 08:40 PM. |
Re: Converting 2WD cab to 4WD
hello,finnally found post i was looking for,hope this saves you some grief,there
is also talk in some of my post about bushings too. ![]() http://67-72chevytrucks.com/vboard/s...54#post1439254 |
us111,
Thank you thats exactly what I was looking for. I knew it could be done. Great Job. I would love it if you could email me some more pics. I can weld and stuff so now I can get busy. Thanks again. My email is pasotruckparts@yahoo.com Thanks Tony |
Next!
Bushings are different, cabs are the same except for hump. some also have removable humps as my 83 K30 does, the military 86 K30 M1031 does not.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
still diggin for other pics but think they may have
been on hard drive that crashed. just remembered when i bought bushings someone from here told me 2 buy bushings for the frame year which worked but the rear bolts (new)were different lenghts or something (trying to remember).ended up working out but i had to reuse something from the old bushings.it will come to me (i hope) someone will jump in with more knowledge.start cutting! lol Last edited by us111; 06-08-2008 at 03:04 PM. Reason: more info |
Well I have brand new poly cab mounts. I bought the whole kit. A guy I sold the parts truck too said I would need to use a 2 1/4" spacer (he used pipe) to get the rear of the cab level. I haven't measured everything but it does seem to be diff. He also said to use a 2" body lift so I wouldn't have to screw with the floor. Thats a little to hokie for me..
I will be doing the cab cut out for sure. When it comes to putting on the new hump, do they make those nuts that stay on the truck so when I bolt the hump down I don't need to be under the truck. Thanks again, Great pics by the way thanks they really help |
yes i was told same thing,with body lift it
would work but did not get into all that.as far as the bolts u would have to weld nuts,myself i just used self tapping bigger screws,works fine. |
Sorry,I don't have any pic's yet,But if you are going to lift the truck at all you just need about a 1 1/2 body lift or lower the transfercase about the same.The cabs are the same except for the hump!!I have done a few in my time and I like the smaller hup for the xtra room.Good Luck!!!!!!!!!!
Thank to all that replied. I think this will work out fine. I will redo the floor and not deal with the body lift.
Thanks again, Any and all suggestions and tios still welcome. |
