Quick Question
I recently searched for info on the best way to install my new intake manifold and I was just wondering if the "Hi-temp Ultra black RTV" would work ok...? I also just wanted to double check to and make sure that the intake bolts needed to be torqued down to 30 ft lbs, right? Thanks for the help.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Quick Question
Intake torque specs 25lbs and RTV works best in the fron and rear valley areas. Not on the heads...lol WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Re: Quick Question
Thanks. What should I use then?
![]() Join Date: May 2008
Re: Quick Question
Use intake gaskets on the heads and RTV on the front and back rails.
Mine is chopped, has a clutch, and a big block. |
Re: Quick Question
I believe the last stuff I used was the ultra grey. Thin application just around the water passages on the heads on both sides of the gasket and a healthy bead on the block front and back. No leaks yet.
