#26 | |
Gone to greener pastures
![]() Join Date: May 2007
Re: Rust Removal by Electrolysis
I didn't reread the entire thread. I read through it all when it was new, but not this time. And the other procedure that I saw was after riveted1's original; And I just happened to remember the washing soda. Have yourself a great weekend.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#27 |
I don't think your mesh is working correctly as the (anode). When I do this I use a piece of scrap steel and it always bubbles at the scrap steel. Try it with a peice of scrap steel in the corner. The stainless might be messing with something.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#28 | |
Tasty Cakes!
Some notes: El Jay is correct. I've heard that regular baking soda will work, but takes much longer, and the results may be lackluster. That is because sodium bicarbonate is less basic than sodium carbonate. The negative terminal has to be on the parts you are cleaning, otherwise the reaction occurs in reverse. So you are currently adding material to your parts! You also don't want to use Stainless Steel! The process will create toxic fumes and is dangerous. If you have a section of pipe or something laying around, use that. It will be much safer. Just my .02
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#29 |
Been doing it for years to clean up old tractor parts. I have found that the best stuff to use is Arm and Hammer Washing powder. I do like to use a piece of Stainless steel to use as the anode (red lead) as it will not get eaten up like a piece of steel will and if you do much of this you will realize how fast you eat the anode up. Here is a pic of a 1929 John Deere D wheel that I did, had to flip it but it really turned out nice. Don't hook it up backwards, it will actually eat up the part you want to de-rust. THE BLACK LEAD goes on the part you are trying to remove rust from!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#30 |
Questionable
hmmmm, i wonder how well this would work on some steelies (wheels)?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#31 |
It would work good Shifty, not as quick as blasting them though. If you add a little red devil lye It will completely strip paint and leave a nice black coating on the wheels.
Jeff
#32 |
So where would I find soda ash?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#33 |
Questionable
i just want to save myself the effort of trying to get sandpaper down in the cracks, nooks and crannies and was thinking about putting naval jelly on it.
#34 |
I would think that any place that sells swimming pool supplies would have it.
It's not really all that exotic.
#35 |
Tasty Cakes!
Aha!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 06-13-2008 at 03:01 AM. |
