Old 06-16-2008, 11:37 AM   #1
heavy71chevy
heavy71chevy's Avatar
Oil tube broke off
Ok so heres what happend..I had my bottom end resting on the crank pulley while I was bolting it to the engine stand and it fell over...The oil tubr that runs into the block bent and sanpped off...how do I get the old one out, and the reinstall the other? and my last ? where can I get that part?
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 06-16-2008, 05:24 PM   #2
heavy71chevy
Re: Oil tube broke off
"Dixie Destroyer"
71 C10 LWB Fleet
Old 06-16-2008, 06:02 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
The last one I got was from the dealer, but it was an '86 block. It was a dirty beeyatch to get the old tube out. Had to pull the pan and try tapping it out, which worked partially. Then I ended up using a drill bit that was just a tad smaller than the hole the tube goes in and it grabbed the broken piece and spun it out of the block. I hope it isn't that bad for you as I probably just got really lucky.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-16-2008, 06:02 PM   #4
El Jay
Gone to greener pastures
I've used an "easy out" to get a couple out.
You might want to take a propane torch and heat the block a little bit also.
Decide when you are going to install the new tube, then put the tube in the freezer the night before.
Most auto supplies carry after market tubes & dipsticks.
You'll probably have to buy both of them, though.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-16-2008, 07:14 PM   #5
Gray Ghost
Gray Ghost's Avatar
Easy....drop the pan and tap it out from underneath....you can get a replacement at any O'Reilly's [or some dealers have the stock ones].
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-16-2008, 07:38 PM   #6
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Mine had a little lip left to it, so I just popped ita couple times with a flat screwdriver and hammer, then grabbed it with a pair of vice-grips
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-16-2008, 07:45 PM   #7
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I would avoid pulling the pan or heat.....try the easy out with some penetrating oil.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 06-16-2008, 08:06 PM   #8
JimKshortstep4x4
I use a large sheet metal bolt with a hex head. I screw the bolt in and then use claw hammer or similiar tool to pry it out. I have done several this way with no problems.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-16-2008, 09:34 PM   #9
jimfulco
Thread a screw or bolt into it like Jim said, then put a small open-end wrench under the bolt head and tap the wrench head upward with a hammer.
jimfulco is offline   Reply With Quote
Old 06-17-2008, 01:49 AM   #10
Gray Ghost
Gray Ghost's Avatar
Jim
Never thought of that one Jim....not a bad idea actually. I'll have to try that next time...sure beats dropping the pan. Mine happened to coincide with a pan gasket change.
Kelly
