06-17-2008, 02:15 PM | #1 |
67 GMC Frame and BB Motor Mounts
Here's the question thoughs of you who have a 67 with a Big Block what motor mounts did you use? Was there any modification you had to do. I have 72 and 68-71 motor mounts and they do not fit properly. Not for sure what to do now. Any help is appreciated.
Thanks, DREW67
DREW67 |
06-18-2008, 08:01 PM | #2 |
Re: 67 GMC Frame and BB Motor Mounts
Maybe this will help Pictures!!!
DREW67 |
06-18-2008, 08:16 PM | #3 |
Registered Mail
you must trim the frame rails in the area i highlighted, I took some photos of mine, but i forgot the camera at the shop, I will post them up this weekend if you like, it clearly shows the area to trim, after that the mounts fit perfect!
its ends up being about 1/2" of material to cut off.. but there's lots of meat there.
'67 chev 496, lwb to swb, bagged - pro street project |
06-18-2008, 08:40 PM | #4 |
Thanks, but I really hate to cut the frame.
DREW67 |
06-18-2008, 08:48 PM | #5 |
Registered Mail
well, as far as I know it's either cut a notch, or drill new holes in the frame.. I haven't found anyone to get around it yet or make them fit, unless they build new perches..
not sure whats so bad about notching the frame a little? the '68+ come factory notched to fit the mounts i believe. same thing if you want power steering in a '67. I pounded in a dimple into the frame rail just like the '68+ frames come stock.
06-18-2008, 09:01 PM | #6 |
You are right I just measured the frame rail on my 72 and it's 1-3/4" and on my 67 it's 2-3/4 wow I never paid attention to that. I guess sense I have both mounts which ones are the best 68-71 or 72 motor mounts.
DREW67 Last edited by DREW67; 06-18-2008 at 09:01 PM. |
06-18-2008, 10:08 PM | #7 |
I see you got it figured out Andrew!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
06-18-2008, 10:12 PM | #8 |
Joe which mounts are better 68-71 or 72
DREW67 |
06-18-2008, 10:13 PM | #9 |
Use the 72 mounts. They're safer and they isolate the engine vibration a lot better.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-18-2008, 10:17 PM | #10 |
Thanks Guys this was very helpful!!!!!
DREW67 |
06-18-2008, 10:23 PM | #11 |
I would use the 72's also
06-18-2008, 10:27 PM | #12 |
Then it's a deal the 72's are going in.
DREW67 |
