Truck pics after Disc brake convert,new grill and wheels
before
no grill just after disc brake convert
new grill after installed yesterday
side tonite
Pronounced "Pew-al-up"
Where did you buy your grille??
Sure looks great, clean truck.
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
pass side morning
bought grill from GMC PAUL
Did you strip the truck of the moulding, or did you buy it that way??
I stripped mine too, but sometimes wish I would have left the bottom on!!! ![]()
looking good
i love summertime
what kinda fender is that? did it fit as good as the original?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
bought the truck with molding gone I want to lower it and go with bigger wheels but next step is body work and rust repair
the fender came from GMC Pauls it fits great I think I need to shim the bottom up a little behind the wheel well I'll do that when I get my new inner fenders
Case_bt
Here is my '70 with a 2" drop. I also want to lower it another 3" with some drop spindles!!
![]() Join Date: Mar 2000
Looking Good case_bt!!! I can't wait to see the finished truck when your done with all mods!!!
#15 |
67-72 Addict!
Both you guys have sweet trucks!, case bt what is the name of that color?. I'm trying to talk my dad into painting his that color.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#16 |
It the teal green
Chevy used in the early 90's on the fullsize and Geo Trackers |
#17 |
Low & Slow
Sweet truck! Keep us updated!
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
#18 |
case-bt
Who makes that fender does it has CY stamped in it anywhere? Because I bought two 67 fenders and they dont fit very nice. Later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#19 |
Truck Pic
I've got that one saved to disk. Very nice truck. TF
#20 |
72Mario
I bought the fender from GMCPAUL IT fits great I just need to shim the fender up at the bottom behind the fender well probably correct with just one washer |
#21 |
Got earplugs?
Where did you get your disc brake convert done?
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
#22 |
I did the conversion myself using 71 parts
spindles rotors calipers outer tierod rubber hoses 70 model outer tierod for new inner tierod CPP tierod adjuster conversion part. I have one extra set part # cp4sc http://www.classicperform.com/6092chevtrk.htm |
