06-14-2008, 09:49 PM | #1 |
You want it there when???
Delay wiper module
where is the module for the delay wipers mounted on the 86 silverado and what does it look like? tks
1986 Silverado Flatbed 400 SB with 350 turbo 1997 Ford Explorer with 302 mydrive to work ride 1978 Gmc Midas RV 21ft with 46,000 actual miles 2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow Big Sandy Survivor 09 Trucks in the Blue Grass Survivor 09 TNCTC Streetcruzin |
06-14-2008, 10:22 PM | #2 |
In the Forgotten far North.
Re: Delay wiper module
It's black with an aluminum heat-sink and is mounted cross-wise to the underside of the of the steering column right behind the lower dash cover panel. To remove it simply grasp it and slide it straight up the column then disconnect the wiring harness's at either end of it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
06-14-2008, 10:27 PM | #3 |
Ok tks will check it out
06-16-2008, 04:50 PM | #4 |
Insert Witty Text Here
It looks like this:
Slonaker |
06-17-2008, 05:32 AM | #5 |
Can a non-delay be made a delay wiper by replacing the switch and adding the heat sink?
06-17-2008, 06:12 AM | #6 |
Old Heap Driver
I did. Picked up a column from a 1984 Blazer along with the module and added both to my 1980 C-10. I had to sort out the wiring, for mine the wire colors matched. Eliminated to dash switch and use the column mounted switch from the Blazer column. Works great.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
06-17-2008, 06:15 AM | #7 |
One shot, one kill.
Bob, the answer is yes, thats how GM did it. Wiper motor is the same. You'll have to change the signal light lever also. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
06-18-2008, 02:36 PM | #8 |
Does anyone know what the module costs and if i can get it at a major store? The Autozone bufoon on the phone had no idea what it was...
G to the M to the C......fool! RIP Jerry Reed "The Snowman" |
06-20-2008, 11:22 AM | #9 |
Anybody?
06-20-2008, 11:26 AM | #10 |
I looked in to that at a local parts store and they couldn't find a listing. I think it will have to be bought from a dealer. I ended up finding one at a local pull-a-part and got lucky...it worked.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
06-20-2008, 12:51 PM | #11 |
Yep it's a dealer item only.
06-20-2008, 02:20 PM | #12 |
Kinda makes me wonder what other vehicles had this style of delay on them it might open up the possibilities of finding one in a junk yard in another restoration catalog (ie: Classic Industries Camaro). Does anyone have a picture of one installed on a column? I have recently bought a tilt column and it has the delay turn signal lever but I see no delay module on it.
06-20-2008, 02:59 PM | #13 |
I'm even kind of wondering if one can simply not use the delay module and just plug the 2 harnesses into one another. Can you do this? I don't really need delay wipers anyway; I just want wipers that work! Can you use the wipers without the delay and just replace the module when you feel like, or is it best to replace it right from jumpstreet?
06-20-2008, 03:51 PM | #14 |
I'd imagine that any 80's -90's GM product with the same style column would have the same unit.
06-20-2008, 04:00 PM | #15 | |
