Beside getting the new hood, fenders, grill and bumper -- do I need to change the radiator core support ?
Are all of these parts direct bolt ons -- once the 72 stuff is out of the way ? What about the inner fenders ? I want to know what I'm getting into before I do it !
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry 71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster 70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges |
Here We Go: You will need 67-70 bumper brackets a 67-68 Rad Support contrary to popular belief that the 69-72 they can be use they can't. You will need a support from a 67-68 Grill that goes from the hood latch (You can use your hood latch for your 71 it's the same) down to the Grill and from the Grill to Rad Support.Oh the head light bezels trim for the grill You can use Your old headlight buckets , And the last thing is the tubs they are the same. I am in the process of doing the same swap. Have fun getting thoes body lines right ! Send me a PM if you have anymore Questions. Later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 02-04-2003 at 09:16 PM. |
If you are leaving the rear marker lights, you would be better off with a 68 front clip. It is the same as the 67, but it will have the marker lights.
Thanks for the info, Mario !
Haven't decided to go w/o markers or 68 front fenders.
Cool
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
