Old 06-17-2008, 10:08 AM   #1
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
NP205 Only seems to have 4hi - neutral - 4lo
Hey guys,
I've had my truck for a few years, and still seem to be having the problem with it not being able to go into 2wd. All the way back is 4hi, then it still has the front driveshaft engaged all the way until neutral. I know it is definitely a 205 and not a 203. Is this a common issue? Something that can be fixed by adjusting the shift linkage, or does it need a rebuild?
Thanks for any advice.
'76 k2500 -- almost done...
ben@speedbarn is offline   Reply With Quote
Old 06-17-2008, 02:50 PM   #2
hdflstf
hdflstf's Avatar
Re: NP205 Only seems to have 4hi - neutral - 4lo
I vote shift linkage. I was thinking broken roll pin on a shift fork but that would allow a mix of high and low - then BANG... So it's not that.
Is it actually driving the front or is it just internal friction of the gears, bearings, and lube turning the front?
I would try - disconnect the front driveshaft and turn the front output by hand with the truck in park, engine not running (or in gear for a stick) in each of the TC shift positions. The front should not turn by hand in 4 hi or low but should turn in 2 wd.
hdflstf is offline   Reply With Quote
Old 06-17-2008, 03:02 PM   #3
ben@speedbarn
Done yet?
Currently I can only turn the front driveshaft by hand when the Tcase is in neutral. I'm not sure what taking the drive shaft off would give me?
Old 06-22-2008, 03:18 PM   #4
hdflstf
hdflstf's Avatar
Sorry, wasn't thinking about having the front hubs not locked.. No need to disconnect the driveshaft.
I'm voting for linkage issue of some sort. If not it sounds like a shift fork loose on a shift rail?
Old 06-23-2008, 08:26 AM   #5
scott123
coming off of your shifter check the pin/hole that attaches the shifter to the two shifter rods on the case...my plate hole was 'oblonged' due to years of use...i didnt have full range...those plates are easily re=welded and drilled, or anothe can be made from flat stock...good luck...scott
scott123 is offline   Reply With Quote
