69 Fleetside, Build and Sell!
before i get started i want to let everyone know that wants to maybe say some bad things about the way im doing this truck, since people do love these things and so do i.... i dont have the time or resources to do a truck completely right (welding in new sheet metal in bad spots, etc), im pressed for time since this is basically to put some money in my pocket and fund the truck i really want (64 short stepside for the wife) when i get back home. and a 66 nova ss for me. im selling to a specific demographic here (younger kids who are in the military, just moving to the island, looking for a sweet ride and something to blow their paycheck on..happens all the time)
after deciding that i wanted to get some practice on some older cars before i move back home and find the one i want to build, i found this 69 fleetside for 2,000 here in honolulu, already had a 350 with edelbrock performer intake mani, edelbrock 600cfm carb, hedman headers, and msd ignition, recently rebuilt and powers through a th350 auto trans. the truck runs smooth as glass, sounds awesome, doesnt have a single leak out of any hose, no vacuum problems, and the underside frame is literally in perfect condition, no deterioration in the frame at all. the body is also in very nice condition for the area it was in and what it was being used for (bought it from a nice local guy that owned and worked in a cemetary here, and used the truck to haul dirt back and forth). when i got the truck i took some starter pics, so here it is, the major areas that need work are the driver and passenger running boards, the front right fender, and the top of the inside of the cabin where the visors are at (common areas). this is my first restoration, real bodywork/bondo car, paint job, and a first for a lot of things so we will see how it goes, my plan is to spend 2500 only on the truck , and resell for around 12 when it looks complete enough to put on the market down here. List of parts i already bought for the truck, and money already spent. New DS and PS runners (below the door) - came with the truck Weather strip set (all of it) - came with the truck Dash grate for where the dash meets the window - came with the truck new knobs - came with the truck New tailgate new gauge bezel and lenses overhead vinyl cover new cabin light 6" drop springs for the rear (cutting front) cherry bomb glass packs new chrome door sill plates also i have a friend here who does alot of his own work and recently sold his 70 rs camaro and had alot of leftover parts not used, so i got from him Flame thrower Distributor chrome 100 amp alternator 750 cfm holley carb so heres the pics ![]() ![]() interior is in great shape as well, no rust inside except for the overhead area, going to put in a new stereo and replace the AC unit with a tri-gauge autometer setup to get some extra gauge in theres that dont come stock. and replace the vents with small tweeters. truck has perfect glass all around as well. ![]() heres that trouble spot, planning on removing all the rust, getting it set clean, primering over to prevent further rust and then using fiberglass resin and cloth to form a new overhead area, then ill be covering with a black cabin felt ![]() all the hardware inside the truck works great, windows are good, the triangle windows are working, the wipers and lights all work ![]() its on the 15x8's and ill keep them on it and take off the chrome parts, get them powdercoated black or paint them black myself, then put the chrome parts back on them. the side of the truck is in good shape as well, minor rust spots minus under the doors. ![]() already purchased a new tailgate to replace this one, i dont need the extra hassle of opening a tailgate to replace internal movie parts or trying to tear it apart to smash it back into shape, easier to just spend 100 and get a new one. ![]() like i said, the guy used it as a dump truck in the graveyard, fitting place for a truck going under huh? the bed has since been cleaned out and has too much dent and rust damage on the bottom of the bed to be used, so ill either be replacing with a wood bed, or finding a bed liner after removing the rust and resealing it with primer and paint. ![]() drip rails need work but the damage doesnt go all the way through to the cabin as far as i can see, it may have soaked through enough to cause damage inside the cabin as seen before, but im planning on doing my best to salvage what i can, and remove all the surface rust then filling in with lead body filler to create a lip around the cabin that looks like it belongs, shaving will be too much work for the amount of time i can spend on this truck ![]() engine bay is in great shape as well, just needs tlc and some spit shining. ![]() like stated before, completely rebuilt, with the listed mods before to the engine, it just needs a new dist cap since its showing its wear, and some performance tuning (mechanical advance to be put on with the new dist) Last edited by Kracin; 06-24-2008 at 02:24 PM. |
Re: 69 Fleetside, Build and Sell!
OK! updates on the first post because i am lazy and didnt get this post up when i first got the truck, but alot of body work is complete after only 2 weeks of on and off time working on the truck.. i have to drive it to an auto port where you rent a stall/lift and use their area to do the work since i live in an apartment here on the island, good thing the autoport has lifts, tools, air tools, and everything you need.. even a paint booth, sand blaster, welding machines, pretty much anything to rebuild an entire car! for 2 dollars an hour hah. so i ended up shaving the antenna off the truck as part of some of the first body work because i dont plan on having a radio like that in it, just a cd player with internal antenna, and decent sound system (as i said before, trying to sell to a certain crowd). ![]() alot of other bodywork was done on the left and right side, and ill be posting updated pictures of those when i remember to get them off my camera. but the next thing done was i change the exhaust on the truck, it HAD a flowmaster exhaust system on it, and the system looked fairly new, but i cant stand a quiet v-8, the sound of the car is just as important as the appearance to me, so i went ahead and put on 2 2.5" 30"-long cherry bomb glass packs and have the exhaust routed out the side of truck on both sides. the truck sounds great now, and theres no question to whats under the hood when people hear it, and its definately not too loud as i tested the sound difference with and without the cherry bombs... big difference that a glass pack makes too. ![]() more updates as more time gets put in. |
Looks like it could be a good starter. So to make sure of your plans what you want to do is clean it up, repair what you can and just hide the rest. Than try pray on some guy who is protecting our country and screw him out of $12K! Yep I am sure you will get a great response from this site
![]() Kevin LFD Inc. Last edited by Rokcrln; 06-24-2008 at 06:18 AM. |
Tot Roddin'
![]() Welcome to the board from Mid-MO, but do the right thing and spend the extra money, and you will receive it in return.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#5 | |
Tasty Cakes!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Under Construction
I was like what..... If you cant do it right, it's not worth doing it at all.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
On the fast track to nowhere..
I can't say it would bother me if you were doing it for your self. But hiding problems under fiberglass and vinyl to sell a truck for the same money as a cleanly built one doesn't sit well with me. Maybe because I'm part of that "certain crowd" repairing a doctored up hack job.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
ok well maybe i didnt explain it good enough, im not hiding rust, or anything like that, im removing all rust, doing a good patch job, but i dont have the time or skills to replace everything with new sheet metal, which is where the fiberglass stuff comes into play.. and lots of body panels are either repaired with or replaced wholly with fiberglass, am i wrong?
but the truck wont be "pieced" together, its already a nice truck as is, and as i stated i already have A LOT of NEW parts to install on it.... this is my first chance to do real bodywork on an older car, im mainly an engine and performance person so im using this as a learning experience with it. but no, im not trying to dupe anyone into buying a truck that is a pos or anything like that. im building it up to look nice and sell to the people i know will want it down here.... if i wanted to sell it to someone who collects classics i would keep it around stock ride height, paint it the traditional two tone or green....... not lower it and use black and orange.... im sorry everyone is misreading what i put up, but i hope that everyone can understand to each his own is a term used best when talking about cars. but just for one more times sake, no, this isnt a hide the rust, dont tell them the problems, dupe some kid truck.... read the post one more time and look how much work and parts is going into it... thanks everyone and i hope that i can be some kind of help to the board later on when i get a garage of my own and tools i need to work on my next truck properly. |
![]() Join Date: Jun 2002
My take is it is your truck, do what you want with it. It's hard to make a profit on these trucks (I never have ...) but you can repair them without doing a full resto. Make it safe and reliable and you are ahead of the game.
I think there's a big difference in doing it cost effectively and doing shoddy work... Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Tot Roddin'
Well put...
#12 | |
thank you for the positive post, and i hope others can understand that not everyone has access to a 2 car garage, 12 hours of work on off days or more, and lots of access to parts or junk yards for scrap.... here in hawaii, everyone is on a order it only basis (shipping costs a ton), and im in the military so off time is a rare thing. ill still post pics of the progress regarless, and maybe the others will understand that its not "shoddy" work or bad patch jobs, its just a matter of materials and time that come into play, plus im married and cost of living is tough here so i need to keep costs down, i didnt see anyone flaming another guy who only wanted to spend 5500 on a full resto for his build.... thanks though Ian |
To be completely honest....Fiberglass and old rust dont mix...just leads to lot bigger problems.If you have access to a welder the rest isnt gonna take to much time to resolve...they make a patch for that lip above the windshield and the rest is an easy peice to make from a small piece of sheetmetal...I know first hand what filling that spot on the roof with fiberglass does befause the ass jack before I owned it did it to mine....My drip rails are completely rusted away as well as part of the roof...Like said before if you aint gonna do it right...just leave it alone till you can,sell it to someone and buy something less rusty..classics are just that and its to nice to rig up for a quick profit to some poor dude who isnt suspecting it to be like that....Just my two cents
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster Last edited by heavy71chevy; 06-24-2008 at 04:08 PM. Reason: forgot part |
#14 | |
![]() Good luck, Rg
#15 | |
maybe i should just close this thread if people are so closed minded that they think that there is only 1 way to restore a car.. what if i were to take off all the bodypanels and make fiberglass replacements out of all of them, would i get flamed for that? and why would i get flamed for using fiberglass patching in areas that dont get any physical contact with anything besides a hand reaching for a visor... and patching an area that has been rusted away with fiberglass resin and cloth is a good way to do a patch, its in no way a way to do shotty work... only if th eperson putting the patch on doesnt do it right or doesnt take their time.. |
#16 |
KRACIN, i think the problem that people are having id how you are wording what you are intending to do, quote "...and why would i get flamed for using fiberglass patching in areas that dont get any physical contact with anything besides a hand reaching for a visor... and patching an area that has been rusted away with fiberglass resin and cloth..." if you read your post again you can see where people are having issue with what you are doing. The main thing is that people on this board have all been burned by PO in one way or another and just want to make sure that doesnt happen to other hobbyist looking for a truck, just find find hidden problems. I know form personal experience what fiberglass repairs in rusted areas lead too, alot of problems and more rust. But the bottom line is that most members on here, from what ive seen, do not use fiberglass to repair metal panels when replacing with metal patch panels is just about the same amount of work in the end.
Hopefully you can understand what everyone is saying. |
#17 | |
ok, i understand, but its never a good thing to post on something assuming the worst, they might as well save comments until something happens. i dont get why they would call a hole repaired with fiberglass, a hidden problem.... its a legitemate patch and easier for someone that cannot weld or doesnt have access to a welder and is on a budget and cant pay someone to do it for them. please tell me eastwood is advertising wrong for their fiberglass repair stuff..http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT.. that was just a quick search, but just like it was said before, its about HOW the repair is done, not what it was done with. i myself have seen people who weld in new panels in all kinds of places, and do such a ****ty job with the welds and sealing it and grinding it down, that you can see where they put the patch in and it starts rusting and chipping in a matter of months. ill stop threadjacking my own thread, and let my work do the talking for me so the others can be put at ease once the project starts coming together. thanks for all the positive (and negative) replies, criticism is criticism right? Last edited by Kracin; 06-25-2008 at 03:08 AM. |
#18 |
Restoring a 68 SWB
These guys love these old trucks. Do it right and they'll stand up and applaud you. Heck, they'll be thrilled with you if you make some money. They just wanna see you do it right, and believe me they know what "doing it right" means. Just read through some of these build threads. Good luck with the truck buddy and thanks for serving our country.
P.S. I spent alot of time in those garages on base when I was in the military. I would like to have something like that out here in the civilian world.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#19 | |
Kevin LFD Inc. Last edited by Rokcrln; 06-25-2008 at 06:00 AM. |
#20 |
![]() Join Date: Apr 2005
Wow!! This is a touchy subject. KRACIN, I understand your dilemma with not having the proper tools (hopefully the hobby shop on base can help you out with that). The problem with the fiberglass repair is that it won't last and most of the guys on here have had to deal with them at some time or another. AND they usually make the initial problem worse depending on how well they are done. If you still want to use fiberglass, take lots of pictures of the repair and show them to perspective buyers, at least that way you can say you made full disclosure, (there's something to be said for being able to sleep at night,
![]() I would like to say this too, buyers need to ask more questions and do more research. Don't get over anxious just because you see something that has shiny paint and nice wheels. If you want to see how well a truck is built, you need to get underneath it. In my experience, that's where people skimp or cut corners. Last but not least, ask for some before pictures. Usually, anyone doing a quality restoration will have plenty of pictures to show you. If they don't BUYER BEWARE.... R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#21 | ||
younger kids who are in the military, just moving to the island, looking for a sweet ride and something to blow their paycheck on. I just hope that you disclose to the buyer how the truck was repaired so they are aware of what they're getting. Please, don't close your thread, or feel un-welcome here. We all voice our opinions and even though sometimes we disagree we're all welcome here. I just wanted to let you know where I'm coming from. I'm interested to see how this truck comes together, as I'm sure others are too ![]()
#22 |
i have a question, why would you take off flowmasters and install glasspacks? that's just wrong!
#23 | |
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
#24 |
![]() Join Date: Nov 2004
Since your basically putting it out there that this is for sale when it's done it's only fair to say:
Forum Guidlines and Rules Updated 06/29/05 The following are the rules and guidelines for 67-72Chevytrucks.com Discussion Forums. Ignorance of the Rules and Guidelines is no Excuse!!! CONDUCT GUIDELINES & ACCEPTABLE USE POLICY XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#25 | |
If I had gotten ripped like this when I first came to the board I would have never come back... You guys can't honestly say that you have never done repairs in the past that you would not do now. Heck, I've had my days of fiberglass patching (as a matter of fact, I can take a pic of the '64 Chevy truck I sold years ago that I repaired the fenders with fiberglass at least 15 years ago, and they still look good.) I wouldn't do it now, but some people do... and at the time reproduction parts were hard to come by. The only negative statements I will ever make is if I see a safety issue (believe me, there's more to get angry about on the suspension forum than there is in this thread...) As far as selling it, I don't have a clue what these go for in Hawaii, but I'll bet it's more than they go for in Texas or Kentucky... Good luck, Rg
