Old 06-22-2008, 11:22 PM   #1
Lane
Weekend Progress Part II - 5.3 install - pics
Well - finally finished the motor mounts.. Ended up welding the I6 mounts to the plates I made for the 5.3. Got tired of trying to line everything up and make it a bolt on deal. The only reason I didn't weld it up to start with was because of the rubber in the mount. I was afraid of melting/damaging it - or seperating it from the mount itself. Didn't hurt it at all - I just took my time welding - and cooling it off.
Got all the accessories back on:
Yes - the exhaust manifold is backwards. Just thinking WAY ahead.. It does not clear the frame rail(normal), which has me worried about headers. I'd like to run Mac mid lengths(F-bod), but I'm not too sure they'll work either. If not, guess I'll be making headers too.
One last shot:
Lane is offline   Reply With Quote
Old 06-22-2008, 11:24 PM   #2
GRIMSS
GRIMSS's Avatar
Re: Weekend Progress Part II - 5.3 install - pics
I was thinking you were going turbo with the exhaust that way.
Keep the pics coming.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-23-2008, 07:21 AM   #3
scotts62
One day...
scotts62's Avatar
Heck ya that looks good!
Scott
93 crew cab build
Project 62
Old 06-23-2008, 09:33 PM   #4
TR65
TR65's Avatar
Hey Lane,
Thanks for all the pics and info. The motor mounts look good.
I have a 6 litre to go in my 65 and I was planning on using the cast iron exhaust manifolds. It looks like I have a ton of clearance with the frame rail. They might hit the motor mount but not the frame. They look very similar to yours but not exactly (mine are from a SSR). Where exactly are you hitting?
Thanks,
TR
PS. I was going to use header wrap or something on mine. The cast manifolds are pretty hard to beat power wise. In the tests I have seen the headers can usually barely match the cast iron on LS1 / LS2.
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-23-2008, 09:35 PM   #5
1974k5blazer
sweet man! how is all the wiring going to be??? fairly easy or what?
1974k5blazer is offline   Reply With Quote
Old 06-23-2008, 09:51 PM   #6
BlueJeep
BlueJeep's Avatar
I believe the stock truck manifolds splay out too far to where the frame would have to be notched to fit them. There was a post on the 67-72 forum where the guy notched his frame around the manifolds to fit the stock truck ones.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-23-2008, 10:14 PM   #7
pcmcobra
pcmcobra's Avatar
fbody manifold will probably fit, they fit my 86.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-23-2008, 10:20 PM   #8
Lane
Originally Posted by TR65 View Post
Hey Lane,
Thanks,
TR
Yeah, some of the stock manifolds flow very well - especially the Vette's. Your motor must be sitting higher, because the manifold on mine just comes down too far and hits the rail all along the main runner. It(header) needs to be either closer in to the motor or not hang as low.
Header wrap should do the trick for heat.
Old 06-23-2008, 10:24 PM   #9
Lane
LOL - I've got some good pics of my harness - that's spread out all over a room in my house. :yikes: I'm switching to a fly-by-cable setup so I'm going to have to change/add some plugs on the harness I have(fly-by-wire harness) -which will be the hardest part of it. Other than that, I have it all cleaned up and ready to add relays/fuses and it's ready to wire up.
I'll post some pics on that as well when I get to that bridge.
Old 06-23-2008, 10:27 PM   #10
Lane
Yes - too far out and too low. It would take some serious notching on my truck to make it work..
An F-bod mandifold may work. I've heard of guys using long-tubes with this setup no problem. But they had after market mounts - or home-made mounts.
Old 06-23-2008, 10:34 PM   #11
billysbowties
billysbowties's Avatar
DAD BURN IT
This is what I was afraid of, I had my heart and soul set on putting a 5.3 in my truck and the way it looks your going to have to do some wild bending or notching your frame or something. Please post anything you figure out on this and if there is anybody out there that has already accomplished this please let us know something.
BB
billysbowties is offline   Reply With Quote
Old 06-23-2008, 10:57 PM   #12
greg64
greg64's Avatar
Looks great, Lane! Looking at your passenger side motor mount pic, I see your "secret" for increased fuel economy!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-23-2008, 11:01 PM   #13
joe231
joe231's Avatar
Billy, there are a few trucks on here with the new gen small blocks, it can be done.
i believe super73 has one in his drag truck, might pm him and see if he will give you some input.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-23-2008, 11:24 PM   #14
Lane
Here's one - a '68, but the frame is the same right?
F-bod LT's - it's tight, very tight on the passenger side, but it's in there. His motor may be a little farther back than mine.
billy - it my take some tweaking, but overall it looks like these motors were made for our trucks!
Old 06-24-2008, 12:22 AM   #15
1974k5blazer
can't wait to see it all done man!
Old 06-24-2008, 01:35 PM   #16
Chevysdominate
Chevysdominate's Avatar
Whats the ground clearance like with those headers?
Chevysdominate is offline   Reply With Quote
Old 06-24-2008, 01:46 PM   #17
billysbowties
Thanks for the great pictures, they look great. What size exhaust is that and what do the headers come from. I don't know if a 68 frame is the same width as a 66 (is it). Oh and buy the way what is F-bod LT's.
Thanks again
BB
Old 06-24-2008, 05:20 PM   #18
TimE
Hey Y'all!!
TimE's Avatar
Not positive on the frame widths but I believe that they are very close if not the same. As for the meaning of F-Bod LTs, it is short for F-Body(Camaro/TransAm) Long Tube headers.
TimE is offline   Reply With Quote
Old 06-24-2008, 06:25 PM   #19
billysbowties
Thanks alot.
BB
Old 06-24-2008, 10:33 PM   #20
Lane
Here's a side pic:
This is not my truck btw
Old 06-24-2008, 10:35 PM   #21
Lane
You can tell in this pic that he's going to have issues on the passenger side. Looks like the header is resting on the rail.
Old 06-25-2008, 12:36 AM   #22
Fastrucken
Junior Member
Fastrucken's Avatar
Those are Pasesetter headers. Last summer they were 399 and are worth every penny. I used those for my 5.3 swap. The end of the collector of the d/s has to be angle cut to clear the frame rail, but not too bad. Ground clearance is excellent. My exhaust guy went under my stock tranny crossmember. they fit good, even with my column shift (4l60e of course)
I bought a set of mac mid length but if memory serves me correct I was going to notch the top of the d/s frame. the bends coming off the exhaust ports was not tight enough. The pacesetters fit way better.
It doesn’t look like a flex fuel motor, but looks like you don't have a separate return line off of your fuel rail. The non returnless is way easier to run because only one line is needed to run all the way to the front. I used aluminum line and some high pressure fuel line (will get the brand if you want, its way cheaper and better then the efi fuel line from napa) and used the factory fittings. the russel fuel line adapters are prone to failure and are expensive.
Also I like how you used the I6 engine stands. I ended up spending 40$ on the normal adapters, but I already had the v8 stands. I think it ended up moving the motor back further because I had the same coils you have on your engine but had to swap for the round ones because the square ones wouldn’t fit on the p/s.
Let me know if you have any questions and I will try to get some pictures too.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 06-25-2008, 01:37 AM   #23
Lane
Graham
Great info! Not a big fan of Pacesetters, but if they fit well compared to Macs I guess I'll start looking for a pair. Heck, I may just make my own and save some money.
Made these a few years ago for a '67 Chevy II swap:
I hadn't even paid attention to the single fuel line - which you're right, that's all it's got! I get kind of focused on one thing, then the next.. The fuel system is a few weeks away, after I get the rear gas tank. I may PM you for the part # for the line you used.
Old 08-23-2008, 03:57 PM   #24
TimE
Hey Y'all!!
TimE's Avatar
Any updates on your progress?
Old 08-23-2008, 04:55 PM   #25
padresag
frames are the same from 64-69
ron
padresag is offline   Reply With Quote
