Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-24-2008, 08:01 PM   #1
PA-IndianRider
PA-IndianRider's Avatar
Nitrous Explosion & BAD fire
Check out this video I found while surfing around ..... get the marshmellows ready!!
http://videos.streetfire.net/video/w...ion_164337.htm
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 06-24-2008, 09:06 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Nitrous Explosion & BAD fire
That would SUCK!!! Not sure what was feeding that fire but it was definately spewing molten metal there for a bit. Wired thing is the battery cutoff 'should have' killed the fuel pump and the fire!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-24-2008, 09:28 PM   #3
71Dragtruck
71Dragtruck's Avatar
You'd think at least the driver would have been smart enough to run back and kill the batterys right away?????? Then #2 close the nitrous bottle while the other guys worked on the fire so when the solenoid seals burnt out it wouldn't have fed the fire like that!!!!! That track needs to do some serious training, WOW.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-24-2008, 09:48 PM   #4
PA-IndianRider
Nowadays when you see soooooo many drag racers using "nitrous" with pass after pass without any issues you can get lulled into a false sense of "security" about using it.
Same thing with other issues like safety rules like roll cages, belts, helmets, suits, etc..... with pass after pass without a incident again the "lull factor" emits a false sence of security.... then something like the "Scott Kalitta tragedy" snaps us back to the reality of the "extreme danger" that is only seconds away in this sport.
What a "sad" commentary about the dangers that are down the 1/4 mile. May he rest in peace. +
John aka "Milner"
