Old 02-03-2003, 07:00 PM   #1
cableguy0
did the th400 metric trannies have a lockup verter
i need to know whether or not all the th400 metris=c trannies have a lockup converter or not and how to tell if they do or dont.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-03-2003, 07:35 PM   #2
crazy longhorn
Fabricate till you "puke"
I dont know of any 400 turbos with lock up converter. some of the 350 turbos did have a lock up (350C)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-03-2003, 07:42 PM   #3
cableguy0
ok i was asking because i know a lot of the metric 350's had a lockup verter and a friend was asking about a 400 hes going to use in his chevy.thank u
Old 02-04-2003, 12:23 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Never heard of a metric 350 or 400....the 200 was refered to as a metric though.
If it actually has a desicnation od C after the name, then it is in fack a lock up tranny... But I'm with crazy Al on this...never heard of a lock up 400.
lock up isn't all ppl make it out to be. 200 RPM drop is not much. Just enough to hear and to take away the torque.
Old 02-04-2003, 01:09 AM   #5
cableguy0
i dont too much care for the lockup myself but the pan says metric on it and the tranny is from an 82 i believe i was just asking for a buddy
Old 02-04-2003, 01:50 AM   #6
86k10
metric or not
I'm with the others, I've never heard of a metric 350 or 400, if it says metric on the pan then it's probably a 200 or a 2004R. Myself i don't mind the lockup, course I have mine fixed so I can shut it off if I want and then for road driving kick it back on, cause when a lockup up convertor is unlocked they generate imense heat and fast. i suppose all you Chevy guys will hate me when you find out that as my name says 86K10 is powered by a 7.5L
Oldsmobile. Hey at least it's GM. And it was just an experiment I've always wanted to try. It worked out quite well, now that it has been changed from 3:08 to 4:10 gears and a 69 C20 rear axle with detroit locker, it's a regular powerhouse and still only runs 2200 RPM at 75MPH.
86k10 is offline   Reply With Quote
Old 02-04-2003, 09:39 AM   #7
Jwill41
Jwill41's Avatar
I am running a 700r4 without the lockup in my 68. I am not sure of the rear end gears but it works great.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 02-04-2003, 10:13 AM   #8
ckhd
ckhd's Avatar
I just looked at several transmission sites on the internet. They all list T-350s w/ lockup and without lockups, but none mention lockup at all for the 400s. Judging from that, my bet would be that there are not any T-400 lockup transmissions.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 02-05-2003, 12:22 AM   #9
Low67C10
Ive often wondered if a switch-pitch pump/front support could be modified to work a lock-up convertor.
Low67C10 is offline   Reply With Quote
Old 02-06-2003, 12:25 AM   #10
Longhorn Man
If memory serves, you need a special verter to run switch pitch.
