Old 06-29-2008, 09:52 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Gas pedal question....
What set-up did you guys use for you gas pedal? Right now mine is mounted way up on the fire wall and makes it difficult to drive so i ordered a eliminator pedal and cable assembly was just wondering if anyone else has this set-up?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-29-2008, 10:33 AM   #2
prostreeter58
prostreeter58's Avatar
Re: Gas pedal question....
I used the lokar with the cable linkage kit................
prostreeter58 is offline   Reply With Quote
Old 06-29-2008, 11:23 AM   #3
solidaxel
solidaxel's Avatar
Check out Chevy Duty, they had a stock one for V8,for the 5-6-7 truck and inexpensive
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-29-2008, 12:33 PM   #4
Gene Sharp
Hello prostreeter 58
If you would show us a picture of the brake pedal and master cylinder set upand any info
you r truck looks good and I like the view from the top of the brake setup
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 06-29-2008, 01:37 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Very nice thansk... Thats what I was looking for..
MEMBER #6377
Project "7DEUCE"
