Old 06-29-2008, 09:47 PM   #1
spr85gmc
spr85gmc's Avatar
Re: Lowering the 87
i have my factory rallys just had to grind od about a 1/4 of in inch to prevent rubbing but i would highly recommend going 5/5 if not your going to hate the wheel gap in the front.
*no shims needed
* shock extenterders included
* stylintrucks.com
spr85gmc is offline   Reply With Quote
Old 06-29-2008, 10:32 PM   #2
pcmcobra
pcmcobra's Avatar
Re: Lowering the 87
x2
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-30-2008, 09:08 AM   #3
azfab
azfab's Avatar
Re: Lowering the 87
have you thoght about a z? you could run stock spindels and a stock spring for a nice ride. but its alot of work. planing to do it for my 86. i will have some pics when im ready.
azfab is offline   Reply With Quote
Old 07-01-2008, 05:08 PM   #4
spr85gmc
spr85gmc's Avatar
Re: Lowering the 87
that would be smooth and better yet still ride like it was stock.... but how deep are our pockets
Old 07-01-2008, 06:34 PM   #5
azfab
azfab's Avatar
Re: Lowering the 87
lol yeah it only takes money. its no that bad if you can weld youll be alright its th cheaper way to go. you wont need drop spindels, controlarms, all that good stuff just some welding and grinding. ill be going mine soon, ill take alot of pics.
Old 07-01-2008, 06:40 PM   #6
azfab
azfab's Avatar
Re: Lowering the 87
for the rear what it did was calle summit up and ordered some spring perches for a 2.5 wide and a 3'' axel tube and set my pinion angle up (after i moved the axle on top of the leafs) welded them up and bam you have your own flip kit for 20. cant beat that.
