Restoration steps?
So I'm at the point where everything is off but the cab and the engine so im thinking from here i should do all this:
remove cab and engine shorten frame powdercoat frame/axle buy new brakes, suspension, power steering, etc. powdercoat engine block, do whatever work needs to be done to it. buy new transmission buy sheet metal floor, firewall, rockers, start working on the cab once the cab is finished and primed, install new cab supports install new doors and line up and adjust take cab off, get the inside painted install electrical and dash components make sure the truck starts buy 67 front end, install and align as needed buy new box, install sides, front and rear, adjust if necessary take the front end off, get it painted, reinstall same thing with the box have i missed anything? obviously it isnt this easy but i just need to make sure i dont miss any steps |
Re: Restoration steps?
Find chest of gold, then buy my 70 project when I'm done building.
wheres the fun in that?
that about hits the nail on the head dont forget though about wiring thats the funnest part!
1975 C-10 Silverado LWB
Just my opinion, I would say take the time to "smooth" out the engine block. Just sandpaper to make it have a nice smooth texture. We had a block come into the machine shop with that work done to it. It looked amazing. Hell, I almost wish I would have taken a picture of it. Lots of time involved, but I say if you are going to powder coat it it would be worth it.
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
Old Skool Club
![]() Join Date: Jun 2001
The first thing on your list should be:
Inherit a ton of money, or win the lottery. My truck is also "disassembled", like you describe. I have amassed many new/replacement parts. The suspension is done, the truck was being driven daily (until '02) and it became an ornament in my driveway, awaiting the massive inflow of cash needed to attempt your plan. I have made a deposit on the body/paint, and am awaiting the completion of the work. Patiently at times, not so patiently at others. Now, the guy working on it has been diagnosed with lymphoma. I wonder what will happen next, and I don't want him to die from his illness, nor end up with a truck that is a running basket case. Plan your work....work your plan.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
haha i have a plan i just need money
and a miracle that i get the cab back in one piece, the thing is rusted to hell, but i dont want to **** around with different vin numbers and all that with a new cab, so im just trying to fix this one |
