Hey guys I recently picked up a '69 C10 SWB for a little truck project that me and the better half can do together.
Anyway, it has a late '70's 350 engine in it (junkyard special I am sure) and it idles and drives normal very smooth. However, anytime I get into the throttle past half way and the engine speed goes up it starts missing and popping/banging through the exhaust. I can feel the loss of power as well. Its got a HEI distributor already, but I went ahead and changed the cap, coil, rotor, plugs, wires, etc. and I played with the timing (10* initial). I also swapped the carb out for another one and still nothing has improved. I haven't pulled any valve covers yet, but I don't hear any unusual valvetrain noise. Ideas? Thanks guys!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Chevy nut
Re: Popping & Banging Under Heavier Throttle...
Cam. Thats what's wrong with the 350 I took out of my 69 fleet.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Active Member
![]() Join Date: Jul 2007
Yes. Pull the valve covers & turn the engine. Watch for valve/s that don,t open very far. You probably have lobe/s worn down on the cam.
Green club
that's the first thing that 'popped' into my mind when I read this too, bad cam.
I know, bad joke ![]()
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
Pulled the driver's side valve cover, its a flat lobe on the exhaust side on #5. Maybe more I haven't pulled the passenger side valve cover yet.
