Old 06-21-2008, 02:51 PM   #51
cparman
sharp as a marble
Re: Brake Lines
Ok here goes. There might be pics, and there might not
I painted my master cylinder with the paint in the picture. I put 2 coats on it, letting it dry for 24 hours in between. Used a fom brush. Did this on my last car and it looked great 3 yrs later
cparman is offline   Reply With Quote
Old 06-21-2008, 03:58 PM   #52
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
I have see those mounts. CPP has left, right, and under the MC mounts. which ever way you can get it to work. Now I need brackets for the booster.
VDOG is offline   Reply With Quote
Old 06-21-2008, 06:47 PM   #53
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Originally Posted by Gulf Rat View Post
Found this pic of brake setup for 71-72 hope it helps.
Attachment 364992
Gulf Rat
Looking at ths setup, theres line unions from the prop valve down the the cross member. My 69 has a union for the front brakes only to reach the left and right wheels. The rear line goes down, and behind the crossmember to the passenger side of the inner frame and unions there. I had to take off my headers to install these. And they still dont line up correct. Is there more bending I should be doing?
Old 06-22-2008, 12:23 PM   #54
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
After removing the headers and driverside shock this is what I have. Now where is the shipping bend?
Old 06-22-2008, 12:24 PM   #55
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
And the rest of the bad pictures.
Old 06-22-2008, 12:25 PM   #56
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Last one.
Old 06-22-2008, 01:36 PM   #57
cparman
sharp as a marble
Re: Brake Lines
vdog, I am going to put my truck up in the air, and shoot a couple of pics of my brake lines. I think from what I see, one of the new lines is pointing towards the radiator. That one is for the rear brakes. the other is for the front.
NOW, shoot a couple of pics of the new master cylinder, and the new prop valve. I will rack my truck in a few minutes, and get back to you this afternoon.
Old 06-22-2008, 02:39 PM   #58
70GMCer
70GMCer's Avatar
Re: Brake Lines
The lines you have are for power brakes like mine. Here's my setup. I had to reposition the prop valve because I didn't use their prop valve.
The only shipping bend is the line for the rear brakes that run along the frame to the back by the gas tank and connect to the brake hose.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-22-2008, 03:19 PM   #59
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
I have to get brackets for the booster, but from looking at your pictures I see something that I need to do. The horseshoe bend for both sit on top of the frame, like in your second picture.
Old 07-05-2008, 08:58 PM   #60
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Ok did the Finelines thing, talk to bill again. From the first picture you see the square bend was not next to the frame, and I did not have a shipping bend.
So I bent the square toward the frame and that solved my problem.
Old 07-05-2008, 09:03 PM   #61
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
So now assembly will start tomorrow, here are the painted parts. Forgot to include the painted headers.
