Lowering a 99 dually
I have had my dually for about two years. a year ago I got a kit from a freind of mine and just started doing it this last week. I got front done no problem, got shaft support and bumps stops and rear shackles in back, but can figure out how to remove the rivets in the front spring hangers, any one done this at home. I cut the head off and tried to push through with BFH, no luck.
Re: Lowering a 99 dually
When we did my '06 we burned the heads off with a torch.
It was messy and the coating on the frame kept catchin' on fire too!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
