Old 05-25-2002, 06:52 PM   #1
iluvmy72
Post gear box has some play....should I....
are they hard to rebuild or do I just go to the bone yard?
iluvmy72 is offline   Reply With Quote
Old 05-25-2002, 08:39 PM   #2
Benrs86
Benrs86's Avatar
Post
if you are talking about your steering gearbox there is an adjustment screw that you can tighten it up wiht. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
