Where can I find 6 lug disk breaks
Where can I find 6 lug front disk for 69 c 10
Cadillac power
If you're looking to convert from drum to disc I'd reccomend GMC Pauls. I used their kit and it comes very complete, good quality, good fit and finish, uses existing tie rod ends.
If you just need a new rotor, I'd check NAPA or your local mom and pop.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style. --Scott Adams author of Dilbert |
spindles
thanks for the reply,
are the spindles from a 71 , 5 lug disc going to be the same if I purchase a 6 lug disc. |
its all about the +6 inches
I doubt NAPA can help you at all.
Try GMC paul...he has them. |
Check out Early Classic Enterprises. They make both 5 and 6 lug discs that fit on the 71-72 spindles.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
![]() Join Date: Mar 2000
Yes the 6 lug spindles will go on 71-87 truck spindles using all stock wheel bearings for those years. We carry stock both the 5 lug & 6 lug rotors. If you use the 73 up spindle be aware that there were 2 rotor thickness's used 1" and 1 1/4", the 6 lug rotors only work on spindles that were for 1 1/4" thick rotors.
You can find our rotors here http://www.gmcpauls.com/Brakes&Steering.htm GMCPaul |
