Old 07-07-2008, 08:52 AM   #1
Rooster's82
Rooster's82's Avatar
Seatbelt color
The seat belts that came with my truck are tan, but I'm going all black and gray with a little burgundy for the interior of my steed.
I have used vinyl and fabric spray dye for a lot of stuff, but am nervous about using it on a belt that will be in close contact to me and my clothes.
http://www.autobarn.net/duhipevifasp.html
Has anyone tried this approach before? Or am i better off just looking for a set of belts at the salvage yard?
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 07-07-2008, 12:29 PM   #2
Square84
I don't think these pills work
Square84's Avatar
Re: Seatbelt color
I Used It On My S10 Belts It Didnt Rub Color Off On Clothing, But It Made The Belts So Hard They Wouldnt Conform To Shape Of Your Body And You Had To Force Them Back Into The Retractors. Really Sucked Cause They Were Nice Seatbelts Before They Got Dyed.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 07-07-2008, 01:13 PM   #3
Rooster's82
Re: Seatbelt color
Hmmm, my belts are in pretty harsh shape to start with and don't really like to retract, unless you pull them out and really load the spring. they are stiff with age, too.
I wonder if dying them will make them unusable or since they are already stiff it won't make much difference?
Maybe i will just dye them, if it doesn't work out, all the more reason to get new ones.
JG
Old 07-07-2008, 03:44 PM   #4
westie 666
westie 666's Avatar
Re: Seatbelt color
You shouldn't muck around with seat belts, they are there to save your life, if they are worn or stiff or won't retract they should be replaced with new and never replace from the junk yard.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 07-07-2008, 06:27 PM   #5
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Seatbelt color
It is worth buying a new seat of belts, I just got a set of 3 for my truck, one lap belt and 2 retractable belts for just a little over $200
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 07-07-2008, 06:30 PM   #6
SCOTTROD
SCOTTROD's Avatar
Re: Seatbelt color
Check with a trim shop about installing a different color webbing in your retractors. I don't think its too expensive.
SCOTTROD is offline   Reply With Quote
Old 07-07-2008, 11:01 PM   #7
andresco50
andresco50's Avatar
Re: Seatbelt color
I would buy a new set from LMC TRUCK
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-07-2008, 11:26 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
Re: Seatbelt color
Ok where are you all getting these seat belts ? Does the GM still make these ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-07-2008, 11:37 PM   #9
f.monroe
f.monroe's Avatar
Re: Seatbelt color
Were these new GM belts ?
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-08-2008, 07:45 AM   #10
TexasJeff
TexasJeff's Avatar
Re: Seatbelt color
Frank they were not new factory GM belts, they were aftermarket, but they use the GM buckles. I will have to check the box when I get back home to see the company that makes them. I bought mine from a guy at a swap meet, but took forever to get them, so I dont recommend them. There are lots of places if you search the web that sell seatbelts.
TexasJeff
