Old 07-06-2008, 09:11 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Solenoid on q-jet
What is this solenoid for and is it necessary? My truck is a non ac truck, my first guess was it was to kick up the idle when the AC is on.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-06-2008, 09:32 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Solenoid on q-jet
It an anti dieseling device. You actually set the idle with that and set the screw to where its just about closed.
Old 07-06-2008, 11:08 PM   #3
Sport/Truck
Sierra Grande Club
So, not all trucks got one?
s/t
Old 07-07-2008, 09:35 AM   #4
Wrenchbender Ret
It looks like a idle control for an early partial computer control. If the carb has no other electronics except choke you can use the carb & remove the selenoid or use it for A/c kickup or anti deisel. I didn't see any other elec. sensors in the photo.
Wrenchbender Ret is offline   Reply With Quote
Old 07-07-2008, 11:14 AM   #5
Sport/Truck
Sierra Grande Club
Correct, there are no other electronic controls on the carb. This is also the original carb too. What would cause it to have an anti dieseling device installed from factory?
The only other explanation I can come up with is the fact the engine (although original for this truck) was actually supposed to be used in another truck (going by the stamp on the block). But since my truck was one of the first to roll off the line in ’71 it got some left over parts.
My buddy has an original ‘71 GMC Suburban with AC…and it doesn’t have the solenoid. This is why it’s confusing to me. So the anti dieseling solenoid make sense, but what determined the use of such a valve, I mean this has the factory wiring and everything.
s/t
Old 07-07-2008, 12:25 PM   #6
Wrenchbender Ret
Some of the early emission control systems used a high idle speed & lean idle mixtures to qualify. That made a solenoid necessary to prevent run on. It might be a California truck.
Old 07-07-2008, 02:02 PM   #7
Sport/Truck
Sierra Grande Club
Not a California truck; ordered and delivered in Colorado. ( I have the papers when he ordered it, and the papers when he took delivery) My buddy’s Suburban was ordered in New Mexico and it doesn’t have the solenoid.
It really doesn’t make sense.
s/t
Old 07-08-2008, 05:29 AM   #8
GMCPaul
Its a transmission spark control solenoid. Used on some 69's and all 1970-1972 trucks to our knowledge.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-08-2008, 06:56 AM   #9
Sport/Truck
Sierra Grande Club
Thanks! Is there anything special I need to do to remove this system? I already omitted the two relays off the drivers side fire wall. (I hope its to be a big deal to remove all this).
s/t
You said all 70-72 trucks to your knowledge.... Does this include the Suburbans?
s/t
Old 07-08-2008, 07:17 AM   #10
GMCPaul
Just pull it and your done nothing special needs done, it was used on all C/K ( Truck, Panel Truck, Suburban, Blazer & Jimmy ) vehicles from 70-72 and was probably the first item most owners & shops removed.
Your lucky if you see 1 in 40 trucks with it still attached to the carb but disconnected and rarer yet maybe 1 in every couple of hundred will actually have it still all connected to carb and wiring.
GMCPaul
Old 07-08-2008, 07:20 AM   #11
70c10
67-72 Addict!
70c10's Avatar
I sold one on ebay a few years ago and got more than I thought I would!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-08-2008, 09:07 PM   #12
Sport/Truck
Sierra Grande Club
Interesting idea
s/t
Old 07-09-2008, 07:51 AM   #13
RustyParts
RustyParts's Avatar
I think Its purpose is to keep the engine idle speed the same with or without the air conditioner on. If the engine idle is set at 600 rpm with the air conditioner off and you turn on the air conditioner the compressor load would drop the idle speed down. This solenoid would return the idle speed to normal by extending a shaft to open the carb plates. It was adjusted with the air conditioner compressor turned on by screwing the shaft of the solenoid in or out. Can also be used as a anti dieseling device on vehicles without air by setting the rpm using the solenoid instead of the carb idle screw so when it de-energizes the carb plates completely close.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
