Old 07-01-2008, 09:42 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
How often should an AC compressor cycle?
I'm working on a '77 with AC that was coverted to R134a two years ago by a professional. It was so low on refrigerant this spring the compressor wouldn't kick in and cool. After I added two cans of R134a it blows acceptably cold air and reads in the recommended pressure range while it is running, but the compressor cycles every minute or so.
Am I correct to assume it is still low?
How often should the compressor cycle if it is properly charged?
Is cycling the compressor like this bad?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 07-02-2008, 05:02 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: How often should an AC compressor cycle?
I have the same deal in my '85. I would talk with the shop that did the conversion if at all possible...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 07-02-2008, 09:01 PM   #3
chevymotocross
chevymotocross's Avatar
Sounds like it's cycling too much. Also, as you probably know, the A/C system is a self contained system..... nothing should have to be added, unless it leaked out. For you to add two cans of refrigerant since it was last charged, there is obviously a good leak. I would have dye ran through the system to check where the leak is, have it recovered, vacuumed, and recharged with proper amount (I think it's 3 lbs). With a fresh charge and leak repaired, the excessive cycling should stop when AC is on. Speaking of cycling, it should only be cycling on Defrost, or, when the a/c is on it might cycle some because temperature inside the cab is nice and cold, the compressor must now cycle to prevent the evaporator from turning into a block of ice, restricting airflow. You have a charge problem for sure.
chevymotocross is offline   Reply With Quote
Old 07-07-2008, 10:56 PM   #4
badpeanut
badpeanut's Avatar
I double checked pressures yesterday, and it was low (I was mistaken earlier). I added a third can of R134a to get into the recommened pressure range; now it no longer cycles and it cools very nicely.
Our long cold winters are tough on AC systems (they cause a lot of the older systems to leak).
'70 GMC LWB trailer
Old 07-08-2008, 10:03 AM   #5
75sierraclassic
75sierraclassic's Avatar
what are the recommended pressure ranges?
75sierraclassic is offline   Reply With Quote
Old 07-08-2008, 10:34 PM   #6
badpeanut
badpeanut's Avatar
25-45psi on the low pressure port. I'm on the low end of this now.
'70 GMC LWB trailer
Old 07-08-2008, 10:53 PM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
That's good. Ideally you want the evaporator pressure to be as low as possible without the compressor cycling excessively. Lower pressure means lower temperature and then colder A/C. Adding any more refrigerant will raise the pressure (and temperature) of the whole system.
The only trouble you might run in to is the fact that your system was pretty much empty and you never drew a vacuum on it to get rid of air, non-condensable gases and moisture. They add pressure to the system and again cause it to get run at a higher temperature. Since you didn't fix the leak, you'll be doing this again sometime too...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 07-08-2008, 11:41 PM   #8
badpeanut
badpeanut's Avatar
The previous owner had it in to the dealer every year for at least five years prior to me buying it when it was an R12 system and they couldn't fix the leak that occurs over the winter. I believe an R12 system converted to R134a (using the R12 hoses) like mine is, are even more prone to leak over the winter. I'm sure it will leak down again this coming winter and I'm not sure how to stop it.
Two years ago when it was converted to R134a they pulled a vacuum. I was feeling good since I haven't opened the system and I was thinking the R134a molecules are smaller than air or water molecules (hence making it more difficult for the air or water molecules to enter the system), but what you are saying makes sense that my system likely has some contamination.
'70 GMC LWB trailer
