Old 06-29-2008, 11:26 PM   #1
1969stepside
1969stepside's Avatar
pistons
first on pistons wich is better a 4 valve release flat top or a valve release flat top is there any diffrence if so what? is there a compression ratio diffrence and is there a power diffrence?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 06-30-2008, 03:09 AM   #2
cameeks
Long Fleet Club
cameeks's Avatar
Re: pistons
If you are talking about the difference in compression ratio between the two flat top pistons then there will be a very small compression ratio difference but not enough to notice and no power difference.
About the valve reliefs then Omnivec is right.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
Last edited by cameeks; 06-30-2008 at 01:52 PM. Reason: Posting when I was asleeep :)
cameeks is offline   Reply With Quote
Old 06-30-2008, 08:53 AM   #3
Omnivec
Re: pistons
The reason small blocks use 4 valve reliefs is so they can be used in ether bank of a engine. It is usually for more economical pistons. If its a stock piston with 2 valve reliefs its probably out a High hp engine. The Flat tops well give more power and probable about .5 to 1.0 bump in compression.
67 3/4 Lwb Step side X San Diego County truck
70 3/4 berb was 402 Th400 Dana 60 now just the dana
70 3/4 lwb Fleet Choptop bagged th350 no eng yet
79 rx7 Wide body 350 TPI t5 flat black(The interceptor)
64 comet mounted on a 93 Thunderbird chassis.
Omnivec is offline   Reply With Quote
Old 07-09-2008, 01:38 AM   #4
1969stepside
Re: pistons
so are the 4 valve release better than a 2 release piston?
Members i Have met
Earl Slick68
Old 07-09-2008, 02:59 AM   #5
cameeks
Long Fleet Club
cameeks's Avatar
Re: pistons
Are you comparing flat top to fat top? The valve reliefs don't mean that it is a better piston. The material that it is made of does. You can get a cheap piston that has 2 reliefs in it. If it is aftermarket then it would be stamped with the manufactures name and probably model number.
Chris Meeks
Old 07-09-2008, 09:25 AM   #6
Billla
Billla's Avatar
Re: pistons
You're maybe getting a little hung up on the relief thing Omnivec nailed it - it's just a manufacturing shortcut so the pistons can be used in either bank. Although it has nothing specifically to do with the quality of the piston, typically the "rebuilder" pistons are 4-relief.
In terms of CR, 2 reliefs are generally around -5cc volume; doubling that to -10cc can mean about a .5 drop in CR. Even flat-top pistons will likely have valve reliefs.
Billla is offline   Reply With Quote
