Old 07-09-2008, 12:02 AM   #1
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
8.1L install into 1978 K10…DONE
Well, I am excited as all hell to finally have this never ending project coming to an end and the electrical section doesn’t get much action so I figured I would share these videos here as well.
I still have some fine tuning that needs to be done to the engine controller but all in all it runs very well on the initial start up.
The tuner claims over 400 HP and over 400 lb ft of torque from a stock 8.1L running on a MEFI-4 controller and from what I can tell so far….it feels like they might be right! It has some major gonads!
The audio quality is pretty bad on my camera but you get the idea.
DirtyLarry is offline   Reply With Quote
Old 07-09-2008, 12:14 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 8.1L install into 1978 K10…DONE
Sounds awesome! There's just nothing like raw cubic inches!
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-09-2008, 01:06 AM   #3
SmokeShow
SmokeShow's Avatar
very nice... is it just the angle of the shot or is the engine leaning a little towards the driver's side?
02 Chevy 2500HD D/A EC SB 4x4
MA SCIII trans, EFI Live, 5" exhaust, 5% tint...
83 GMC K30 Crew Cab Short Bed
06 Duramax & ZF6 (to be installed) and more to come...
SmokeShow is offline   Reply With Quote
Old 07-09-2008, 03:50 AM   #4
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
sweet.. sounds good
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-09-2008, 08:55 AM   #5
DirtyLarry
DirtyLarry's Avatar
Must be the angle of the shot as there is no engine lean.
Old 07-09-2008, 05:37 PM   #6
andresco50
andresco50's Avatar
awesome congrats
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 07-09-2008, 06:15 PM   #7
Eyegore
What Hump?
Eyegore's Avatar
Very nice, everyone came running into the room to see what was making the noise. Awesome job!!!!!
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-09-2008, 07:01 PM   #8
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Looks awesome man and sounds even better
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 07-09-2008, 07:39 PM   #9
DirtyLarry
DirtyLarry's Avatar
Thanks guys… Here are a few pictures of the final install.
I have a buddy coming over tonight to help lift the hood back on then need to charge the A/C this weekend.
It runs well enough to drive around to shake out the bugs but there is definitely fine calibration tuning to be done to address cold start issues and wide open throttle performance as well as a some underhood wiring clean up to be done. Also have an issue where the dual fuel tank switch valve causes a restriction on the return side causing the fuel pressure to run around 100 psi so the Pollak tank switch valve is bypassed at the moment until I figure out how I want to deal with that issue. Probably go with a transfer pump to transfer fuel from the LH tank to the RH tank on the fly as there appears to be no fuel tank switch valve with a 3/8 return line.
Old 07-09-2008, 08:03 PM   #10
74 C-30
Dually Pride
74 C-30's Avatar
Very nice, looks awesome!
So any details on the motor? Is it just stock or have you done anything to it? Or plans to do something with it?
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 07-09-2008, 10:31 PM   #11
cochino12
It followed me home?
cochino12's Avatar
SEXY!!!!!!!!!!
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-09-2008, 11:50 PM   #12
BaddBusa2005
BaddBusa2005's Avatar
Very cool, I want soooo bad to do a duramax swap into a 4x4 blazer.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 07-09-2008, 11:57 PM   #13
drbyrdman
drbyrdman's Avatar
Nice! I have that engine in my 2500hd. Did you get a programmer for it. I would like to get more out of my truck.
drbyrdman is offline   Reply With Quote
Old 07-10-2008, 09:27 AM   #14
tvblazer78
Low & Fast!
tvblazer78's Avatar
That is cool!!!
tvblazer78 is offline   Reply With Quote
Old 07-10-2008, 12:02 PM   #15
DirtyLarry
DirtyLarry's Avatar
74 C-30, drbyrdman,
The engine is bone stock running a marine type Delphi MEFI-4 engine controller with tweaked marine calibrations. 420 HP and 490 to 505 lb ft of torque (similar to Marine) will be plenty for this rig so no other performance mods are in the plans. (Although, I have another 8.1L that will eventually find its way into my 68’ GMC that will get the go faster treatment)
This is the same engine that is in my stock Silverado 2500HD but the production vehicle PCM-32 engine controllers are constrained by emissions controls and torque management that only yield 340 HP and 455 lf ft of torque. You can tune the PCM-32 controllers to produce a lot more HP but I prefer the MEFI-4 route as the harness is less intrusive, the engine controller can be mounted right on the engine, and it runs OBD1 rather than OBD2.
You can actually feel a major difference in power between the Silverado and this truck. The Silverado is pretty slow but will pull down a house. The K10 is actually pretty fast and feels like it will pull down 2 houses (scary with a rear Detroit locker!) even though it still needs the fine tuning calibrations done.
Old 07-10-2008, 02:33 PM   #16
manimal
manimal's Avatar
That is flatout BADASS!
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-10-2008, 06:36 PM   #17
69face
69face's Avatar
TOTALLY AWWESOME!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 07-10-2008, 07:03 PM   #18
jchav62
1962 C-10
jchav62's Avatar
Siiiicckkk!!!!!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-10-2008, 07:16 PM   #19
DirtyLarry
DirtyLarry's Avatar
Definitely something different than the common 5.3L and 6.0L swap. What is nice about the 8.1L is it is direct bolt in. I used my existing 454 exhaust manifolds, engine mounts and even Centerforce clutch and pressure plate that was originally on my 350 then later on the 454HO. No need to fiddle around with changing engine mounts, plumbing new exhaust and dealing with an A/C compressor that is shoved down in the frame rail like the 5.3L and 6.0L requires….the 8.1L is definitely an easy swap in my opinion. More powerful too in stock form.
Old 07-10-2008, 07:33 PM   #20
abebummy26
abebummy26's Avatar
Flippin Sweet!
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 07-10-2008, 07:59 PM   #21
72highlander
Sophomore Member
72highlander's Avatar
that's sweet, i had that same based engine in a boat i had. ran like hell. look at raylar for performance goodies.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 07-10-2008, 08:58 PM   #22
drbyrdman
drbyrdman's Avatar
can i put a marine controller in my 2002 2500hd??
Old 07-11-2008, 10:05 AM   #23
DirtyLarry
DirtyLarry's Avatar
Physically, yes….with a wiring harness change. You would lose the use of cruise control and a few other things so it would not be worth it. You can always have your stock Silverado engine controller reprogrammed to gain additional HP...probably not as much as the marine HP numbers as the Silverado still runs OBDII and needs to be emissions compliant.
Old 09-16-2012, 12:33 PM   #24
JCampbell
Larry-
Do you have a "build thread" for this swap? Really been considering pulling the trigger on this swap for my dually.
JCampbell is offline   Reply With Quote
Old 09-16-2012, 01:09 PM   #25
DirtyLarry
DirtyLarry's Avatar
Originally Posted by JCampbell View Post
Larry-
No, no build thread on the 8.1L swap. The install was simple engine R&R, as the 8.1L is a direct bolt in…..no drama like an LS engine. I ran it for the first year on a MEFI-4 GM Performance Parts RamJet/Marine ECM then changed it to a stock Silverado P59 ECM later. Don't ever bother with an MEFI ECM...they suck! That story does have a thread here.
Here is a great thread on an 8.1L swap into a 1ton 2wd dually
by another member.
