Old 05-21-2008, 07:29 AM   #1
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Tach dash rebuilt like new
This has been completly reconditioned. Includes new bezel, tachometer,printed circuit and bulbs. Lens is original but has been polished to better then new conditioned. all gauges have been tested. Needles have been painted. Odometer has been reset to zero.
I stand behind all my work. $450.00 shipping incl. anywhere in the U.S.
KevsClassics is offline   Reply With Quote
Old 05-21-2008, 02:19 PM   #2
Robert Paul Thomas
1967 C-10 SWB LS-6 T-56
Re: Tach dash rebuilt like new
Just a question, what is the easiest way to reset the od to 0?
Robert Paul Thomas is offline   Reply With Quote
Old 05-23-2008, 07:35 AM   #3
KevsClassics
TILT COLUMN GURU
Remove odometer wheel, remove plastic retainer,then starting from the left set each number to nine and turn wheel one more time to 000000
Old 05-24-2008, 06:56 AM   #4
KevsClassics
TILT COLUMN GURU
Complete wire harness for tach Incl.
Old 05-24-2008, 04:21 PM   #5
PossumCountry
PossumCountry's Avatar
Just a question how do you polish the lens? What do you use? Would appreciate some advise.
PossumCountry is offline   Reply With Quote
Old 05-24-2008, 07:56 PM   #6
teamradrz1
teamradrz1's Avatar
Meguiars and Mothers both make a plastic polish and the speed ball works pretty good (just don't polish the side of the lens with the numbers)
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 05-24-2008, 10:58 PM   #7
PossumCountry
Thanks for the advise
Old 06-03-2008, 01:29 AM   #8
KevsClassics
TILT COLUMN GURU
SHOW QUALITY
Old 06-03-2008, 11:43 AM   #9
SWILL
Would this fit in place of any stock dash. Mine is set up where the blinkers and generator light are in where the tach sits. It has an aftermarket tach set up on the column already, I believe its a sun tach, would the wiring for that work for the tach in the restored dash. Im thinking everything should just connect right up, or is it not that easy ? Would love to have that and get rid of all the other after market gauges. Thanks
Shane
SWILL is offline   Reply With Quote
Old 06-03-2008, 08:29 PM   #10
KevsClassics
TILT COLUMN GURU
Shane
Yes it will work in your truck but it will need some rewiring, you will have to change the temp sender to work a gauge instead of a light. you would also have to run a oil line to oil pressure gauge. I have done this many times.
Old 06-03-2008, 08:51 PM   #11
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Kev...do you sell the tach by it's self with wiring harness? I have a really solid dash in my truck just need the factory tach itself. If so how much with shipping? PM me if you would.
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-03-2008, 09:38 PM   #12
KevsClassics
TILT COLUMN GURU
You would also need the inner tins, the printed circuit and also the lens. You would be better off buying the one I haveand selling yours.
Old 06-03-2008, 09:51 PM   #13
semperfidoordie
Thanks I'll look into it. Not quite sure how much I could get out of mine.
Tony
Old 06-07-2008, 01:38 AM   #14
rwilhi
Kev, How much to pickup from you? vs shipping? I am in SF.. Thanks
rwilhi is offline   Reply With Quote
Old 07-12-2008, 07:00 PM   #15
KevsClassics
TILT COLUMN GURU
ttt
Old 07-14-2008, 10:33 AM   #16
DANTIP
DANTIP's Avatar
Super nice work. At the end of the summer I would like you to rework my dash. How long would you need to have it?
Thanks,
Dan
DANTIP is offline   Reply With Quote
Old 07-14-2008, 10:58 PM   #17
KevsClassics
TILT COLUMN GURU
Thanks,
Dan
It would be about 1 week plus transit time.
