how maney people are runing the 40/20/40seats in there trucks and what did you get them out of and how much did they cost how much room do you have ?
64 buick skylark 65 buick skylark 67 chevy 2wd Lb 68 2w Lb 05 chevy colbalt ![]() |
Saving 1 truck at a time!
Re: 40/20 /40 seats ?
Hmmmm....do you mean these? Only available in the '67 and '68...commonly called "buddy buckets". $350-$550 unrestored.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 07-15-2008 at 12:50 AM. |
Yeah And Also The Newer Ones Were Did You Find Yours
I have found these only in '67 or '68 trucks or at swap meets. Some Dodges had a similar style in this era.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Lemme show you something!!
I'm running the 40/20/40 Seats w/ Integrated shoulder belts out of a 2004 Silverado 2500HD. I forked over $350 for them. I just put them in my new to me '67 GMC SWB. They are quite a bit thicker in the back then the stock bench- so I had to move the column in about 3 inches to clear my squishy belly!
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Are You Running The In Cab Tank
![]() Join Date: Feb 2000
I'm using a set of 98 or 99 40/20/40Silverado seats in my 69 K20 and you definitely lose room. You sit a touch higher and you're definitely closer to the dash. Whether you have the in cab tank does not matter as the back of the seat hits the metal portion of the cab that is above the gas tank. You definitely want a tilt column if you use these later model style seats.
Here are two previous threads I have regarding the install of that seat, thread 1 and thread 2 The second thread has a good pic of me sitting in the seat to show leg room.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 07-15-2008 at 12:23 PM. |
You can use the late 90's model bench and I think it is contoured but not as thick as the 40/20/40 seats. You give up legroom, but gain a bit of comfort for sure.
