Smooth Firewall
Is there a company that makes a smooth firewall for 73-87 trucks?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Smooth Firewall
Not that I am aware of. Pretty simple to do it yourself though.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: Smooth Firewall
Thanks for the reply. I was planning on doing it myself, but it would sure be easy if someone made it. Maybe I could make a mold when I do mine.
Re: Smooth Firewall
post it back here if you do
No Life Like Low Life
Re: Smooth Firewall
This is what I did
Eric 1978 Chevy Scottsdale 1960 Impala ZZ4 1965 Buick Riviera GS 2011 GMC Sierra Denali |
It'd be alot cooler if you did
Re: Smooth Firewall
I guess you could call mice semi-smooth.
Re: Smooth Firewall
Did you just fill the holes and leave the factory supports? (I do not mean to discount the amount of effort it takes to do this)
Re: Smooth Firewall
pretty much. I cut out most of where the heater box was just below the pinch weld, and did the same on the driver side as well, and had to rebuild the gas pedal area and weld studs to the inside. On the driver side I used pretty thick sheet metal so it could support having the pedal assembly welded to it. All other smaller holes I just filled in one by one with sheet metal, with the exception of the support for the dash, and where the throttle cable comes through. I left the angeled pinch welds on the upper part of the fire wall - those were a can of worms I didn't want to open, plus they are fairly structural. All in all, if I had it to do over I wouldn't change the way I did it. It's just the right amount of "smooth" for me.
Re: Smooth Firewall
nicely done
75 GMC C-15 short/step factory 454, lowered |
