07-15-2008, 04:53 PM | #1 |
shorty header question
I lowered my 67sw chevy, and now the stupied 2 1/2 exhaust and flows hit the ground on my dirt road in places. I really like the look of NOT seeing the pipes hanging down low. I'll also be bagging the truck this winter. I found some for like $350ish, any place that may be cheaper? I'm not sure what one I priced. I really like the coated headers, the black are ok but they rust.
07-15-2008, 05:22 PM | #2 |
Re: shorty header question
You'll have to modify the frame top rail for Hedmans [67/68 only], but they're cheaper...mine were $139 a set. The black ones take a really long time to rust around our area. If you want coated you get upgraded to 3/8" flanges up top, but I think they are over $300.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
07-15-2008, 05:37 PM | #3 |
Any pics of your headers, price sounds great. Also, how much moding? Where did you get your Hedmans, from just a speed shop? I can paint them with a high heat paint when I get them and they should be ok.
07-15-2008, 05:45 PM | #4 |
I got mine from Summit last winter when I had the original motor rebuilt. Mine clear fine with just a small triangle slice [3/4"] cause it's a 70, but the 67's frame rails are thicker up top and protrude about 1" further into the engine area. I think Bill removed 1.5" on both sides in a gently curved cut. It looks great cause his frame has been painted now...wish I had pics.
07-15-2008, 05:49 PM | #5 |
cutting kinda bothers me sometimes.
07-15-2008, 05:55 PM | #6 |
I understand....I never mind it becuase I always make my trucks my own, but I do understand the other side of the coin. It goes without saying that it's always better not to have to cut, but in this case the structural integrity remains very strong. The 67's have much more meat on them and unless you plan to put a ton of stress on your truck like racing or 4-wheelin' it should be fine.
07-15-2008, 06:05 PM | #7 |
Here's a few pics....
07-15-2008, 06:06 PM | #8 |
PS....spark plug access is easy!!
07-15-2008, 06:12 PM | #9 |
I think I'll get the hedmans, thanks.
07-15-2008, 07:12 PM | #10 |
The 67-8 top rail is a good bit wider, and in 69 Chevy just cut the top down, so if you do the cut correctly without any sharp angles it'll be OK, I just put the header in the right place and mark the frame with a sharpie and pull the header out and cut or grind the top rail. Some headers fit better than others so the amount will for your will be different. Just try to cut as parallel to the frame rail as you can and keep the cut rounded and it'll be OK, look at the 69-72 frames and you can see what GM did to them and they are OK. PS those black sorties look good!! I like the clean bends, without the pretzel look!!
07-15-2008, 07:35 PM | #11 |
1970 Daily Driver
Do you have the part number for those headers?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
07-15-2008, 07:41 PM | #12 |
Retired Air Force Veteran
Big Green,
Since you have plans to bag it, and since your exhaust system is running low - here's a great mod to your Trailing Arms Cross Member. I found this particular build while doing a 67-72chevytrucks.com search. I'm sure there are plenty of build threads on this mod and probably in the FAQ Section. Here's how the pass thru looks. Here's the build thread http://67-72chevytrucks.com/vboard/s....php?p=1781738
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
07-15-2008, 10:48 PM | #13 |
I think it's 2466HKR?????
Thats what I ordered anyway.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
07-16-2008, 12:01 PM | #14 |
hey big green, i just tried installing a set of center dump shortys on a 72 4x4 but they hit the crossmember. i think they would work on your 2wd. if youd like ai can get pics and email them 2 ya. im in harrison ar.
they belong to wrapumup. im shure he would sell them cheap or trade if yours are in good shape? p m me if interested. marvin
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
