Old 07-16-2008, 10:27 AM   #1
fatboys69
fatboys69's Avatar
1 piece windows
Finally got my windows installed, had another thread going with the new door install http://67-72chevytrucks.com/vboard/s...d.php?t=292528. Here ae some pics of the finished work. These are from one piece products ( no corner plates needed ). Sure does let ALOT more air in the cab.
fatboys69 is offline   Reply With Quote
Old 07-16-2008, 10:37 AM   #2
Shock_Me
Shock_Me's Avatar
Re: 1 piece windows
Looks great! Nice and Clean.
My dad has the twin to your truck in stock stance form.
Pete
Shock_Me is offline   Reply With Quote
Old 07-16-2008, 10:48 AM   #3
steelhorse
steelhorse's Avatar
Re: 1 piece windows
How do they work and did you get the power or manual setup?
steelhorse is offline   Reply With Quote
Old 07-16-2008, 12:06 PM   #4
fatboys69
fatboys69's Avatar
Re: 1 piece windows
manual set-up, and they seem to work pretty well. So far the windows DO NOT rattle when they are down and you are driving down the road. Fits pretty good.
Took a total of about 8 hrs to do both doors ( was the 1st one I had done and figured out a few tricks to make the next one even easier ) . The next set should go quicker.
Old 07-16-2008, 12:31 PM   #5
Custom 68
Custom 68's Avatar
Re: 1 piece windows
so do they roll down all the way flush to the top of the opening? I have the Brothers 1 piece and seem to work good I have a problem when rolling the windows up at 65 plus mph they want to suck out at the last 1 inch or so. I did get mos of this resloved as they first did this at a slower speed.
I like them
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-16-2008, 12:58 PM   #6
fatboys69
fatboys69's Avatar
Re: 1 piece windows
Custom 68
they roll down and bottom out on the internal bracket that has the bumper and are below the edge of the door in the rear and about 3" of the leading edge of the front of the glass sticks up past the edge of the door about 1/8", but when I installed the glass wipers you cant see it. ( the wipers are about 3/4" tall and the glass disappears into them, I'll take a pic tonite and post.
Old 07-16-2008, 01:04 PM   #7
El Jay
Gone to greener pastures
Re: 1 piece windows
Looks good.
Both the windows and the truck.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 07-16-2008, 01:28 PM   #8
jkaylor68gmc
jkaylor68gmc's Avatar
Re: 1 piece windows
woooowowooooooothey are done, thank god.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 07-16-2008, 01:32 PM   #9
Hart_Rod
Hart_Rod's Avatar
Re: 1 piece windows
Originally Posted by fatboys69 View Post
Custom 68
I've been waiting for pictures of this install for while. If you could post some lessons learned with the pictures that would be great too. Is there away to modify the the lower bumpstop to get more down travel?
Thanks,
Hart_Rod is offline   Reply With Quote
Old 07-16-2008, 02:30 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 1 piece windows
Those turned out nice, and I'm with Hart Rod, any pics and installation advice would be great!
Beautiful truck!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-16-2008, 02:47 PM   #11
SCOTI
SCOTI's Avatar
Re: 1 piece windows
x3 on the close-up pics + installation observations you would do differently vs. the instructions.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-16-2008, 03:05 PM   #12
fatboys69
fatboys69's Avatar
Re: 1 piece windows
There will be in-depth pics and installation instructions in the Oct/Nov. issue of Truck Builder ( Josh is working on the layout as we speak ). It was pretty much a straight forward install. The only "difficult" part of the whole installation is in "clearencing" the internal bracing ( on the inside ) at the front of the door . You have to "modify" it because the window passes so close to the support. We had to do trial and error as to how much to "modify" as no two doors are the same.
Other than that you only have to change out the 2 rollers that run in the new lift track and cut out the tab at the vent widow area ( so the window will work correctly. Here is the link to the installation instructions:
http://www.onepieceproducts.com/imag...nKit_67-72.pdf
All in all it appears to be a really good kit.
Old 07-16-2008, 03:22 PM   #13
Custom 68
Custom 68's Avatar
Re: 1 piece windows
cool, thanks for the info. I had mine before these came out. Good to see somebody has now installed them
thanks
Dave
Dave
Old 07-16-2008, 03:46 PM   #14
fatboys69
fatboys69's Avatar
Re: 1 piece windows
If I can be of any help with questions or problems please let me know, be more than happy to help in any way possible. I will take some closeup pics tonite and post them. As far as modifying the internal window stop it could be "modified" to allow it to drop ( I just didn't do it, and am going to back up and do it ).
Old 07-16-2008, 05:35 PM   #15
ebfabman
Re: 1 piece windows
Some close up pics of the windows rolled all the way down would be good.....thanks
ebfabman is offline   Reply With Quote
Old 07-16-2008, 05:41 PM   #16
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: 1 piece windows
I am in...I am looking at this kit as well.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-16-2008, 07:04 PM   #17
Mondo
Mondo's Avatar
Re: 1 piece windows
I pick my truck up from the paint shop tomorrow They installed these windows and they look good. He said it wasn't difficult (of course they're a body shop so....).
Didn't get a chance to play with them but will post up pics tomorrow.
Mondo is offline   Reply With Quote
Old 07-16-2008, 07:20 PM   #18
SCOTI
SCOTI's Avatar
Re: 1 piece windows
Originally Posted by Mondo View Post
....They installed these windows and they look good. He said it wasn't difficult (of course they're a body shop so....).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-16-2008, 08:33 PM   #19
chevychase
chevychase's Avatar
Re: 1 piece windows
I didn't know they made them without the corners... I like it!!!
chevychase is offline   Reply With Quote
Old 07-16-2008, 09:24 PM   #20
fatboys69
fatboys69's Avatar
Re: 1 piece windows
Mondo,
are yours from ONE PIECE PRODUCTS also?
Old 07-16-2008, 09:55 PM   #21
ebfabman
Re: 1 piece windows
Pictures???
Old 07-16-2008, 09:56 PM   #22
smashedfoot
Re: 1 piece windows
is there any wind noise .
smashedfoot is offline   Reply With Quote
Old 07-16-2008, 10:18 PM   #23
Mondo
Mondo's Avatar
Re: 1 piece windows
Yes, they're from One Piece... they were all the way up when I stopped by today. All new glass and corvette red paint! They were putting it back together so I can't wait to see it all cleaned up.
I also put in some LED taillights and the headlights with built in turn signals (the front of the 67 looks a bit cleaner), shaved sidemarkers/mirrors/gas cap too.
It's a mid-price job which is good enough for this truck. Sorry to go on like this without pictures.... pick it up tomorrow afternoon and will post as soon as I get her home.
Old 07-17-2008, 09:24 AM   #24
fatboys69
fatboys69's Avatar
Re: 1 piece windows
OK here are the pics with the windows up and down.
Here are the UP ones.
Old 07-17-2008, 09:25 AM   #25
fatboys69
fatboys69's Avatar
Re: 1 piece windows
Here are the ones DOWN
