Old 07-15-2008, 05:46 PM   #1
koolky
67-72 Addicted
koolky's Avatar
Quick axel question
Ive got an Eaton rearend here from a leafspring 3/4 ton truck. Do leaf and trailing arm trucks use the same mounts on the rearend. Thanks
koolky is offline   Reply With Quote
Old 07-15-2008, 06:12 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Quick axel question
no, they do not.
Old 07-16-2008, 05:49 PM   #3
kcjones
I wish I was a cowboy
kcjones's Avatar
I bet I know what you're up to, koolky...I've got an Eaton as well, and to get a 12 bolt out of another truck, the easiest to find in good shape are the 73-87's, which are all leaf. I'm grinding off the leaf pad and welding on some trailing arm pads, shouldn't be very difficult. I'm actually thinking of tacking them down once I set the pinion angle, and then taking them to someone who knows how to weld really well to lay the bead.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
