02-08-2003, 12:02 AM | #1 |
Some pics of my truck
Just wanted to post my progress! Hopefully be done in time to cruise the summer months away....
Thanks to everyone here, I have hurdled many obstacles during the build. This place is great!
69 chevy SWB 70 GTO 65 GTO hardtop 65 GTO ragtop 77 Trans Am Hmmm. Too many pontiacs, not enough chevy trucks yet. |
02-08-2003, 12:03 AM | #2 |
another one.........
02-08-2003, 12:04 AM | #3 |
.............and another
02-08-2003, 12:05 AM | #4 |
another
02-08-2003, 12:06 AM | #5 |
one more.
02-08-2003, 12:07 AM | #6 |
...........and a plug for my shop..................
02-08-2003, 12:23 AM | #7 |
SLOW BUT SURE,BUT CLOSER
Sweet lookin' ride!!!!!! looks great!!!!!!! Is that the new Chevy color?
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
02-08-2003, 12:24 AM | #8 |
Active Member
Sweet! real nice work
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
02-08-2003, 12:25 AM | #9 |
Nice Truck what do you have in that for a drop and what wheeles are you running ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-08-2003, 12:57 AM | #10 |
Thanks guys!! I dropped the front with 2 1/2 inch drop spindles, someone had already cut the coils, not sure how much exactly, they made a nice clean cut, the truck still rode good, so I figured I'd just leave them. I flipped the rear axle, c notched it, had the rear leafs rearched, and then decided I still needed one more inch in rear, so I put a one inch block under the springs. I figure I'll still get another 1/2 inch drop in rear after the rearched springs settle. The wheels are 16" Boyd Coddingtons, with Radial T/As. Wanted some 17s, but I got this set for 600.00 from a buddy, and I couldn't pass them up. Plus, I decided I really liked how they looked. I tubbed the rear though, and eventually would like some even wider to fill the tubs.
As far as the color goes, I'm not sure what yellow it is. I took the cab and front clip off of a longbed chevy I bought at an auction, I loved the shade of yellow, so I just had a digital color match done, and will paint the whole truck the same yellow again. So, all I have is a formula. PPG is calling it Sunburst yellow I think. Thanks again guys!!
02-08-2003, 12:59 AM | #11 |
By the way.........72 Mario.......if that is your truck in your avatar, I really like it. It was the source of much inspiration for me to build a truck.
02-08-2003, 02:09 AM | #12 |
You've got yourself a nice ride started. I actually thought that the truck in 72 Mario's avatar was your truck. I was going to ask it before I read your last reply.
Brandon |
02-08-2003, 02:40 AM | #13 |
nice ride
02-08-2003, 04:03 AM | #14 |
Really nice job, keep us posted!! Doug
02-08-2003, 09:45 AM | #15 |
Great truck...........keep the pictures coming
-1972 K20 longbed -350 4 Barrel -4 speed |
02-08-2003, 11:11 AM | #16 |
Quality work. It looks like the summer will be a lot of fun.
02-08-2003, 12:49 PM | #17 |
Nice looking truck..be sure to post some pictures when its done..nice job!
02-08-2003, 03:47 PM | #18 |
Car Knocker
Nice truck dude! Is the engine painted same color or rattle can? My engine is the same color using VHT but is starting to peel off after 3 yrs of daily driving. How did you paint yours before I pull mine to start over.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
02-08-2003, 06:34 PM | #19 |
Jay........The engine is the same paint I used on the truck itself. When I had the engine built, I told them to just leave the block bare. I then degreased it, sealed it with a 2 part sealer, and then base/cleared it. I did the same to my GTO 3 years ago, and it is still holding well. Much better than a rattle can.
