72 Nova headers on truck
I run across an awesome deal on a set of headers for a 72 Nova.I did a search but nothing really came up ....gotta be somebody here has tried a set on a C10.If so could you post your results...thanks in advance
Real Projects never die
Re: 72 Nova headers on truck
68-72 or 74 nova have the same sub frame as the 67-69 camaro i believe, so they should work.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
Morning, Yes the subframes are interchangeable. I have a set of headers for the first gen Camaro (full length) and I looked at them & compared them to the set of headers I removed from my truck and the big difference seemed to be that the Camaro headers did not have as much distance (vertical) from the exhaust port flanges to the bottom primary pipes where they make the turn to the back, compared to the correct truck headers. Now I'm talking a set that came off my '77 I have no idea how far down the 67-72 needs to be. With all that said they might have fit... but they would of been very close to the floor board firewall area. You would really need to do a trial fit to make sure, or wait for a positive confirmation from someone else who has done it successfully.
God Bless, Terry ![]() |
thats what i,m wondering ...how close to the floor would they be
#5 | |
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 Last edited by gearhead1968; 07-17-2008 at 03:19 PM. |
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 |
they look like they fit not bad gear head
I tried the correct ruck headers, but they hung down way to low, so I thought that I would give the Camaro headers a try and I am happy with the fit. It is really close to the frame on the passanger side and close to the lower control arm on the drivers side but it works and they don't hang down to the ground.
