Closed Thread
Old 07-08-2008, 11:12 AM   #801
Richard D
Richard D's Avatar
Re: How about some pictures of '73-'87 short beds
I agree, that one sits about perfect. I like how the space between the rim and fender is the same front to back.
Richard D is offline
Old 07-08-2008, 11:37 AM   #802
SCOTI
SCOTI's Avatar
Originally Posted by upon1 View Post
wow that is a deadly truck! what is your suspension setup and tire sizes??
The front drop is 3" Bell Tech spindles w/1 coil cut from the original sbc V8 springs & relocated upper shock mounts.
The rear has the HD spring option (8-leaf spring pack) w/a Western Chassis flip kit (for 6" drop) plus Bell Tech drop shackles. I've added Western Chassis c-sections w/home-made air-over-leaf brackets & a couple of small dbl convoluted bags for leveling the truck when I want to still use it as a truck.
In the pics, front wheel/tire combo is 20x8.5 w/5.25"BS & 255-40/20's. The rear is 20x10 w/5.50"BS & 295-40/20's.
It looks sweet but the drop combined w/the tall front tires did not work well. I can't get my knuckles in between the top of the tires & the wheel well & it was very apparent on the short drive I took it on this weekend. I swapped my ralleys back on for now.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 07-08-2008, 12:22 PM   #803
SCOTTROD
SCOTTROD's Avatar
Man, I like that truck with the coys on it.
SCOTTROD is offline
Old 07-10-2008, 06:54 PM   #804
gafiredog
thats a bad ride scoti
gafiredog is offline
Old 07-18-2008, 10:21 AM   #805
slash crashley
lucky knuckles
slash crashley's Avatar
Thumbs up
heh. i haven't heard "deadly" for a lot of years. i'm going to try and work it back into my vocabulary, it's a classic.
awesome trucks in here fellas.
slash crashley is offline
Old 07-18-2008, 10:54 AM   #806
SulphurDave
SulphurDave's Avatar
Originally Posted by MickMc View Post
How did you get that dash pad so smooothee and shinny?
Mick
it's fiberglassed
SulphurDave is offline
Old 07-18-2008, 11:09 AM   #807
MickMc
MickMc's Avatar
Originally Posted by SulphurDave View Post
it's fiberglassed
Well, that is one simple answer.
Mick
MickMc is offline
Old 07-18-2008, 11:03 PM   #808
rodstored-72
chevy truck fan
rodstored-72's Avatar
I put the Coys that I bought for my 68 on for the weekend & took it up to Kellers the local burger/cruise joint
scott,
i used to go up there a bunch when i lived out there. i used to work for "the gas company" alooong time ago (11yrs) my buddy gerald & i knew alot a poeple there. it was a blast! anyways thought i would share.....
rodstored-72 is offline
Old 07-19-2008, 01:56 AM   #809
flamingbig10
6.0 powered square
flamingbig10's Avatar
I go about once a month, might see you there Scoti
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline
Old 07-20-2008, 11:28 AM   #810
piecesparts
Parts and more parts
piecesparts's Avatar
it's fiberglassed
Did you lay the glass over the original pad, or did you have to do something to seal it first?
piecesparts is offline
Old 07-21-2008, 11:48 PM   #811
SulphurDave
Mick
ok...
Originally Posted by bell View Post
how did you do your dash? IT LOOKS GREAT!!!!
Lots of time, patience, resin, filler, sanding, priming, patience, sanding, filler, sanding.......
It looks amazing! did you strip off the foam and use fiberglass mat??
nope
Originally Posted by benoit454 View Post
I love that dash too but I bet it's gonna glare in the window badly while you try and drive in the sun.
So if you didn't strip it then what was done? Just glassed over the original sanded and painted?
I heard people talk about the glare too but this is not a daily driver and gawt damn it looks good!
Like I said about the dash...
It takes a lot of time and patience to get it smooth. It didn't always come out great looking after the first time it was primed, or the second or the third... I mean we played with it and filled in spots and sanded until it was ready to paint. Don't expect to get it perfect in a day.
I know how it is to do bondo work.
I've done body work for a few years now so I've been through it plenty.
I just wondered if you used resin and mat, which should stick very well and hold it's own, or if you used a filler/putty like bodno or duraglass.
If you used a filler I wondered if you just roughed up the surface or used some kind of adhesive promoter to help it stick to the dash.
It looks great, love it. I figure no matter if it's a daily or not it's gonna glare and probably bad, my black one does I dyed in my monte carlo and so did the 86 k10's I used gloss black and they glare, but I wouldn't change it to save my a$$. I love anything and everything shiney, just the white might be too much, not sure.
Also what's bad about the fillers is how they don't stay stuck to things that are common to expand and contract or flex. Being white, that helps reflecxt heat so that might help you alot, and if she doesn't set in direct sun for a long time that'll really keep it nice for a very long time. Just make sure some idiot doesn't jam their hand down on it hard and crack it.
Yes we used fiberglass resin and mat to make sure it stuck. After that the guy who painted it took it and did his thing with filler and sanding and getting it smooth as possible. Left it alone for a few months just sitting in the inside of my truck. Meanwhile, I did some other projects and then came back to it later. Had a couple spots that lifted a little and he went back and sanded it more and filled in where it was neccessary and painted it.
Old 07-22-2008, 11:22 PM   #812
87_Custom
Hey guys I'm pretty new to the site. Here's a pic of my 87 C10 dad and I rebuilt.
Start to Finish:
[BR]
87 Custom Deluxe, crate 350, 700R4 trans, Prowler Orange, Foose 17" Wheels, real good time.
87_Custom is offline
Old 07-23-2008, 02:49 AM   #813
flamingbig10
6.0 powered square
good looking truck, it must not be you DD, since it doesn't have wipers blades lol
Aaron
Old 07-23-2008, 05:03 AM   #814
watahyahknow
watahyahknow's Avatar
nice colour i was planning he same after seeing the 57 buildup here
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline
Old 07-25-2008, 12:28 AM   #815
80FOUR
80FOUR's Avatar
new stance
80FOUR is offline
Old 07-25-2008, 09:47 AM   #816
spr85gmc
spr85gmc's Avatar
New Rule ---> When You Post A Pic Post Some Info With It Please^
spr85gmc is offline
Old 07-25-2008, 02:34 PM   #817
dooce
Originally Posted by 80FOUR View Post
new stance
how much drop is that, and what size rims/tires? looks good
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline
Old 07-25-2008, 07:11 PM   #818
87_Custom
lol it has wiper blades and taillights now. That picture was taken right when we brought it home from picking up the bed from the paint booth. The lighting doesn't do the paint justice either I need to get a picture of it in the sunlight.
Old 07-26-2008, 01:18 AM   #819
Rodms
Rodms's Avatar
I'm new on here but anyone know where you get fiber hood or front cap?
Rodms is offline
Old 07-26-2008, 08:14 AM   #820
watahyahknow
http://www.usbodysource.com/Pages_Trucks/73-Chevy.htm
http://www.up22.com/chevytruck.htm
i might be interested in the sheetmetal you take off the truck , it looks pretty solid on the pictures
Old 07-27-2008, 02:45 AM   #821
flamingbig10
6.0 powered square
that how mine was, also no seat belts, no windows, and bunch over stuff wasn't on it. My truck need the right light for the pearl to pop, only bright sun light or fluorescent light, heres my truck when it left the paint shop
Aaron
Old 08-03-2008, 12:33 PM   #822
spr85gmc
spr85gmc's Avatar
whats up guys been on here a while so i figured i should post pics of my baby aka BRUNO
just had the wheels and tire put on thiss weekend heading to castroville tx for a cruise next friday.
up and coming plans are
* 91 front end (undecided)
* Paint red/orange and gray two toned
* re-do interior install dynomatt
* bags when money will allow
post any feed back good or bad
spr85gmc is offline
Old 08-03-2008, 12:35 PM   #823
watahyahknow
those torque trush look good under just about anything , realy like those rims
Old 08-03-2008, 12:38 PM   #824
SCOTI
SCOTI's Avatar
Originally Posted by spr85gmc View Post
whats up guys been on here a while so i figured i should post pics of my baby aka BRUNO....... just had the wheels and tire put on thiss weekend heading to acastroville tx for a cruise next friday.
post any feed back god or bad
Loosen up the rear bumper brackets, put a jack under the bumper & lift it to square it w/the body. Looks like the bolts weren't tight enough & someone stepped on the bumper to get into the bed causing it to drop until the brackets bottomed out.
Looks like a solid truck though.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 08-03-2008, 12:42 PM   #825
spr85gmc
spr85gmc's Avatar
i need to get on that tomorrow i just put the bumper on a few days ago so yes add that to my list either that or put the roll pan back on.
spr85gmc is offline
Closed Thread
