Can you run without your dust covers?
On your front wheels, your dust covers for your wheel bearings, do you have to have them? The new wheels I have for the '67 work, but I can't put the center caps on without removing the dust covers.
![]() Last edited by 1Low53Burb; 07-18-2008 at 06:40 PM. |
Re: Can you run without your dust covers?
I would say no. All the grease would just sling all over the place.
Corey.
1972 LWB FLEETSIDE. ![]() ![]() |
Oh, and the life of your bearings would be dramatically reduced due to lack of grease and dirt and debris getting in there.
Corey.
Never mind. Dumb question and even after I took them off the ceneter caps still hit the nut.
Oh well. |
ya I ran into this with mini moon's I did all the work to make snap on mini moons fit my rallys and then found this out, this was after about 2 hours of welding little tits on the wheels for the snap on moons to grab onto, it sucked
ΜΟΛΩΝ ΛΑΒΕ |
67-72 Addict!
What kind of wheels are you using?. Maybe you can use a spacer for the center cap?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
i know a man who is on this board that ground down the hub to make his center piece fit and kept the factory grease cap
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
If a 1/4" would cure your problem, a simple wheel spacer should do. Cheap, easy, very little adverse effect.
Neighborhood Pickle Slinger
Get a b.m.f.h. and flatten them. ;-)
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
A BMFH won't help because the nut still hit's with the cap off. I'm thinking of changing rims. I might be selling these.
#11 | |
Old Skool Club
![]() Join Date: Jun 2001
I believe a spacer is a good point, but just enough of one to create the space you need. 1/4-inch would be too much. Can you get one that is only 1/8-inch? I'm going to use a different cap on my Rallye's. Don't want to, but don't like the small blip in the center of my police caps.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
