Old 07-18-2008, 11:24 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Shifter ?
Can anyone tell me what this shifter is for. I think it is out of a '67-72 but I don't know what. Thanks.
LockDoc
Leon
Old 07-18-2008, 11:27 AM   #2
samwise68
FarmBoy.
samwise68's Avatar
Re: Shifter ?
It looks like a floor shift conversion for a 3 speed.
There was one that looked alsmot like that stuck in a '67 I drug home.
there are only 2 rods, and i think a Muncie/Saginaw 4 speed would have 3? I dunno.
I could be wrong..but, thats my guess.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 07-18-2008, 01:37 PM   #3
Ole Blue 68
Ole Blue 68's Avatar
Re: Shifter ?
I'm with samwise on this one, 3 speed shifter.
Ole Blue 68 is offline   Reply With Quote
Old 07-18-2008, 04:35 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Shifter ?
^ I agree,it looks like an aftermarket shifter for a 3 speed.Maybe a "Fenton" or other Hurst Knockoff.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-18-2008, 04:37 PM   #5
caminokid
Chevy nut
caminokid's Avatar
Re: Shifter ?
Originally Posted by samwise68 View Post
Muncie/Saginaw 4 speed would have 3.
Yep my Muncie has 3.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-18-2008, 11:03 PM   #6
LockDoc
LockDoc's Avatar
Re: Shifter ?
Thanks guys. The thing that puzzles me is, I've never seen a three speed setup with that big of a hole in the shifter arm. (where it bolts to the tranny shaft) They should both be the size of the small one....
LockDoc
Leon
Old 07-19-2008, 12:38 AM   #7
Mister laugh
Re: Shifter ?
those arms look a little short to me for a truck 3 speed. Maybe it's just the picture but i was under mine yesterday, and i could swear they looked longer.
Mister laugh is offline   Reply With Quote
Old 07-19-2008, 10:40 AM   #8
LockDoc
LockDoc's Avatar
Re: Shifter ?
I think I will post it up on the 4x4 board too. Just to see if possibly..... I dunno.
Thanks.
LockDoc
Leon
Old 07-19-2008, 10:49 AM   #9
samwise68
FarmBoy.
samwise68's Avatar
Re: Shifter ?
the length of the shift rods could be attributed to it being a '67 or older non-synchroed Muncie.
Those suckers are stubby.
once again..just another thought.
-Sam.
Old 07-19-2008, 10:59 AM   #10
LockDoc
LockDoc's Avatar
Re: Shifter ?
-Sam.
You know Sam, I think I have one of those old short three speeds out in the barn. I will have to go dig it out and test your theory... Thanks.
LockDoc
Leon
Old 07-19-2008, 11:40 AM   #11
LockDoc
LockDoc's Avatar
Re: Shifter ?
LockDoc
Well, that didn't pan out because the mounting holes in the integral mounting bracket are way off, but looking closer at he shifter I found a Patent number. I typed the Patent number into Google and this came up.
Title:
Straight-line shifting assembly
Document Type and Number:
United States Patent 3902378
Abstract:
A shifting assembly in which a shifting stick is moved in a straight line to control gear range and differential operation of a transfer case in a four wheel drive vehicle. A pair of lever arms operable by a single shifting stick actuate the transfer case mechanisms. A gear range lever arm shifts the transfer case between high, neutral, and low gear positions while a differential lever arm is shiftable from a first position to a second to lock the differential mechanisms. Special cam slots in the lever arms are engageable with a pin on a selector arm movable by the shifting stick. A link, operable by the pin with movement of the shifting stick, pivots to effect movement of the differential lever arm while simultaneously disengaging from the range lever arm.
Humm... Now if I can figure out what vehicle it fits. It may not even be GM but it came with some 67-72 Chevy stuff I got.
LockDoc
Leon
