trying to locate new gas cap
hey there.. my gas cap is toast and can't seem to find the proper vented one. It's a 72 but the tank has been changed at some point as there is a vent line routed out from the cab to the charcoal canister thats capped off at the tank. The new tank only has one line comming out of the top (supply) and no provision for the second vent line otherwise I'd reconnect it. The vented caps I've found have the locking feature to far down the neck where the one on there now is right at the top. They look identical other than that. Just figured someone might have run into the same problem and might have a part number for the right one
Re: trying to locate new gas cap
bump.. anyone?
Junior Member
I have a '71 and ran across the same problem with it.
So far I have not put a locking gas cap on it. I just leave mine a little loose, but that means I can never put a lot of gasoline in it. Sorry I can't help, but this will ttt. Danny |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Have you tried your local Napa dealer? Also, here's 3 Board Member/Vendors you can try:
Dennis Chevy Truck Parts Athey's Classic Truck Parts Classic Heartbeat Good Luck.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 07-15-2008 at 09:46 AM. |
just an update.. went to NAPA and foud the right one, my tank is a 70' even though the truck is a 72'. Guess it was swapped at some point. She's venting perfect now, no pressure build up at all!
glad everything is working now.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
