Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-22-2008, 07:15 PM   #1
69halfton
69halfton's Avatar
tires?
hey guys, looking for some new tires for my truck.
its going to be a real daily driver, but i want the tires to have at least a little bite when i go in a strait line.
something in the neghborhood of a 28 inch tire, about 12.5 inches wide and 15 inch rim.
I was looking at some BF goodrich Radial T/A's...
are those any good?
what other tires would you recomend?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 07-22-2008, 10:01 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: tires?
The bfg t/a radials have a wear number in the mid 400s . General grabbers are like 360 . A true drag radial will be in the 40 to 50 range . Nitto drag radials are 100 wear . Unless you buy a drag radial most true radials are going to be in the 300 or above range . Hankook makes a tire that is in the 200 wear range and is R rated . Might check into those . Might not be avalible in 15" though .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-22-2008, 10:32 PM   #3
djracer
djracer's Avatar
Re: tires?
I have a set of M/T Drag Radials but they are about 30 tall.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-23-2008, 12:59 AM   #4
whatnow123
whatnow123's Avatar
Re: tires?
so the lower the wear the better the 'bite"?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 07-23-2008, 09:32 AM   #5
Custom 68
Custom 68's Avatar
Re: tires?
They will be softer so you could assume they should "bite" better.
My Toyo Proxes are some of the better street tires I have tried. They are a true street tire so they dont grip as good as the drag radials.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
