Old 07-21-2008, 11:55 PM   #1
boatpuller
boatpuller's Avatar
help with speedo
my speedometer has made noise on and off for years.i pull the cable squirt some lube in there,and it's o.k for awhile.i haven't had to do it in a long time.i was getting a loud screeching sound.now after reinstall .i'm getting a horrible snap and pop.bad enough to where you need to totaly unhook it.i can't rememeber if you have to push the upper speedo clip in to insert in the back or not.mine just snaps in without pushing the clip in.but,you gotta push the clip to remove it.about ready to leave it unhooked since it's way off anyway due to tire size.any ideas?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-22-2008, 12:30 AM   #2
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: help with speedo
You should never ever wear a Speedo!!! Hope that helps...
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 07-22-2008, 02:05 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
First fix your speedo gear ratios.
http://www.tciauto.com/Products/Tech...eedo_gears.asp
http://www.73-87.com/7387garage/drivetrain/speedo.htm
Use grease instead of oil to lube the cable. Grease will last longer. You have pull the entire center cable out to grease it.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-22-2008, 06:03 AM   #4
Prong
While we're on the subject, what's a good grease to use for the cable?
Prong is offline   Reply With Quote
Old 07-22-2008, 07:23 AM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
guys in speedo's riding bikes with the plastic alien helmet....a horrible sight.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-22-2008, 11:54 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You have to push the metal bar to remove it. I should push on without anything. If it is snaping/popping, remove it from the trans side and see if it is mangled. It may need the cable replaced. Pull it out and if it is ok, lube it and put it back in.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-22-2008, 05:58 PM   #7
boatpuller
boatpuller's Avatar
thanks cap'n.....i thought that's how it worked.just couldn't remember if you had to depress the clip to reinstall,i haven't been. and gchemist,thanks for the links..........and the rest of you joker's.you should hold your speedo comment's to yourself. at least till you recieve the pics of me in mine.which i'll be emailing you.because i know you want them
Old 07-22-2008, 08:00 PM   #8
gchemist
gchemist's Avatar
Use a light lithium grease. Bearing grease is too thick. A light grease works great.
Old 07-23-2008, 07:20 AM   #9
babyJay
babyJay's Avatar
I'm sure you'll have the chance to get us back someday.
Jason
89 R3500 CC SRW
Old 07-23-2008, 07:47 AM   #10
COMP
COMP is offline   Reply With Quote
Old 07-23-2008, 10:48 AM   #11
boatpuller
boatpuller's Avatar
nah...not looking to get anybody back. all in good fun.i enjoy jokin around more than most.....but hey,here's the weird part.iv'e got some request's for those pic's.i'm not gonna mention any names though.i'll keep your identy secret.
Old 07-23-2008, 10:53 AM   #12
babyJay
babyJay's Avatar
I got it, thanks.
Jason
89 R3500 CC SRW
Old 07-23-2008, 03:01 PM   #13
boatpuller
boatpuller's Avatar
good one...on a boat even...that dude is much more of a chick magnet then me.i tried to search yahoo image's for a better one.but whooooo.you get to some site's i don't care to be at in a hurry.i think i'll just stick to looking at chevy truck's.
