04-26-2008, 06:30 PM | #1 |
buffle
400th kickdown
Trying to find kickdown parts for a "72". Right now I don`t have tranny hook-up or kickdown solenoid.
04-27-2008, 02:17 AM | #2 |
Re: 400th kickdown
Are you looking for the wiring harness and transmission detent switch for a TH 400? Normally the detent switch is in the transmission. I may have the wiring but not the detent switch. Can you clarify as to what you are looking for?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-27-2008, 03:07 AM | #3 |
Always on the hunt...
Re: 400th kickdown
I think that he is looking for the pedal mounted switch and wire harness that goes from this switch down to the trans. This one pictured is off a 71 but will work on a 72 or vise-versa. Good luck on your hunt!
04-27-2008, 05:34 AM | #4 |
its all about the +6 inches
Re: 400th kickdown
that is in fact the correct set up for 71 and up (till the 90's)
04-27-2008, 05:51 AM | #5 |
Re: 400th kickdown
early 70s big GM sleds pontiac buick and olds big blocks had same setup. i found mine on a 73 olds 98. my 72 had original goofy temp sender on passeger head and warmup soleniod under dash . i bypassed this stuff and made it work like 71 did. silly g.m. answer to govt. control .
04-27-2008, 06:09 PM | #6 |
buffle
Re: 400th kickdown
Yup that`s what I need, to be honest i didn`t know what it looked like. thanx for the help, I will see what I can find.
04-28-2008, 06:08 AM | #7 |
Re: 400th kickdown
Shanes Chevys had one yesterday at Pate swapmeet. Try to PM him.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
04-28-2008, 03:32 PM | #8 |
buffle
Re: 400th kickdown
Shanes Chevys doesn`t work. Anyone know his PM address?
07-23-2008, 03:09 PM | #9 |
PITbut
Re: 400th kickdown
07-23-2008, 04:06 PM | #10 |
Re: 400th kickdown
the switch should be correct... I dunno about the pedal bracket and stuff though.
07-23-2008, 04:20 PM | #11 | |
PITbut
Re: 400th kickdown
Now that i know how that kickdown works, any ideas how the electric choke would work in my 71? |
