Old 03-14-2008, 11:05 PM   #1
Zonaman
Zonaman's Avatar
Question Return Line Through Fuel Gauge Unit?
It seems to me, I read about someone who used the vapor line fitting on the fuel sending unit for a retun line on a TBI conversion. Right now, I have a '69 with the single feed line fitting on the fuel level float unit. I need to replace that unit and was thinking of getting one for the later models that have the vapor line fitting.
I'm not doing a TBI conversion right now, but since I'm looking ahead to when I do so I'd need to just cap off the line for a time. Any problems there?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 03-15-2008, 02:03 AM   #2
svgould
Active Member
svgould's Avatar
Re: Return Line Through Fuel Gauge Unit?
I did exactly what you stated and have had 0 problems with the set-up.
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 03-16-2008, 09:45 AM   #3
BCOWANWHEELS
i also used it for a diesel fuel return line to tank. no problems.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-16-2008, 09:52 AM   #4
clay68c10
clay68c10's Avatar
I made my own return in the same spot where the later stock vapor line would be and it's working like a champ.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-28-2008, 12:33 PM   #5
Ford Assassin
Ford Assassin's Avatar
Can you please explain how you did this?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
