WOW!!!!! new cam heads
WOW..I switched from a comp 268H to a comp cs268-s10 and had my heads(186) re worked..It used to stop pulling at around 5.000rpm...now it pulls like mad all the way tp 6000..better throttle response..and wicked long powerful smokey burnouts..and this is with out any N20..I cant wait for the track to open
![]() Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
68cst_ss490
Sounds alright, cant wait to get mine to the driving stage, still in the body work phase though.
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
lets see some smokey burnout pics
67-72 Addict!
Congrats Jim!, Sounds like solid cams are a blast. I didn't get mine installed this weekend. Next Saturday I hope.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
What is the difference between those two cams??? Thanks
yea they are a blast...make sure to adjust the rockers after the cam break in(hot) they do change a little..I just cant believe the difference..I dont know if the cam or the heads(or combo of both) made the big difference..I still have my restrictive 2" exhaust on it..the flowmasters will go on tomorrow if I have time.
heres the 268H(hydrolic)
Part Number 12-210-2 Engine 1955-present Chevrolet 262ci-400ci 8cyl. Description -------------------------------------------------------------------------------- Intake Exhaust Valve Adjustment 0 0 Gross Valve Lift 0.454 0.454 Duration At 0.006 Tappet Lift 268 268 -------------------------------------------------------------------------------- Valve Timing At 0.006 Open Close Intake 28 60 Exhaust 68 20 -------------------------------------------------------------------------------- These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 218 218 Lobe Lift 0.3026 0.3026 Lobe Separation 110 -------------------------------------------------------------------------------- Recommended Valve Springs 981-16 hheres the soild lifter.... Part Number 12-676-4 Engine 1955-present Chevrolet 262ci-400ci 8cyl. Grind Number CS XS268S-10 Description -------------------------------------------------------------------------------- Intake Exhaust Valve Adjustment 0.016 0.016 Gross Valve Lift 0.488 0.501 Duration At 0.015 Tappet Lift 268 274 -------------------------------------------------------------------------------- Valve Timing At 0.015 Open Close Intake 28 60 Exhaust 71 23 -------------------------------------------------------------------------------- These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 230 236 Lobe Lift 0.325 0.334 Lobe Separation 110 -------------------------------------------------------------------------------- Recommended Valve Springs 981-16
Now, all you need to do is fix your signature. lol
Sounds like the modifications were well worth it. It seemed fast before when I rode in it, I guess if I am up there I will have to come by and visit you again.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
the redding track is gonna start having grudge drags like twice a month this upcoming season. they start in march
www.reddingdragstrip.net i'm looking to take my truck at least once this year. time's won't look great at least until i get a posi. 406+non posi=no traction
68 short step, 406/700r4, 9" w/discs. |
Sounds good...I know the cam helped, but the heads were sure adding to that new combo. Glad it brought the smile back.
