Old 09-01-2000, 06:09 PM   #1
bigd65
bigd65's Avatar
Post factory headers
anyone ever hear of factory headers around the 87 year model maybe on a 1 ton. i have a set and was wondering if anyone knows anything about them.
jeff
85' C10 350/700R4
LWB with to many add-ons to type
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-02-2000, 09:01 PM   #2
bigd65
bigd65's Avatar
Post
can some one tell me where i can find a web site with information or a web site i might can find some information on these headers
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 09-11-2000, 05:41 PM   #3
bigd65
bigd65's Avatar
Post
well i got the headers on and it runs and sound good,except [ther is alway an except aint there] well i have a whistling noise on the driver side. it only does this on one cylinder and and when i rev the engine or accelerate.im thinking it the gaskets,i used the same ones because they were only acout 2-3 weeks old because i just replaced the head gaskets and all. my question is they are the ones for manifolds with the metal on one side do you think that i should get the header gaskets or should these heve been ok. its been a long time since i had headers.it did not do this with the manifolds so i dont think anything is wrong the motor. tell me what yall think.
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 09-11-2000, 08:50 PM   #4
bigd65
bigd65's Avatar
Post
helloooooooo is there anybody out there
85' C10 350/700R4
2017 Chevy Tahoe
Old 09-11-2000, 09:21 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
Post
Jeff,
if these are steel tube headers, then by all means use some header gaskets. The old manifold gaskets won't get it. They are too hard and won't seal with the headers like they will with cast iron manifolds.
Later,
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Site
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-12-2000, 06:15 AM   #6
bigd65
bigd65's Avatar
Post
thanx again mike thats what im gonna do today
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 10-16-2000, 04:43 PM   #7
bigd65
bigd65's Avatar
Post
well still having a problem getting these headers to seal on the driver side. i found some copper header gaskets and think im gonna try them/ what do yall think of copper header gaskets, will they seal an eaten up flange.its only the surface and thoght i had it cleaned up but must be uneven
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 10-16-2000, 06:55 PM   #8
ImpalaSS
Post
if they are used, the flanges might be warped,,
xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside
64ImpalaSS 68 large journel 327 turbo 350
ImpalaSS is offline   Reply With Quote
Old 10-17-2000, 04:28 PM   #9
bigd65
bigd65's Avatar
Post
im sure that is what is wrong with them but what do you think of the copper gaskets.i heard they were thicker and will seal them if not warped to badly.what do you think
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 10-17-2000, 05:18 PM   #10
swervin ervin
Post
Jeff,
try two regular header gaskets. Sometimes this will give a better seal if the flanges are warped.
Mike
1985 Chevy C-10
Mike
1985 Chevy C-10
Old 10-18-2000, 03:15 PM   #11
bigd65
bigd65's Avatar
Post
mike,
well i got out and looked at it again and i dont think the headers are leaking,there is a more of a cherping sound and it sounds like it is inside the exaust around the cat. the cat and the muffler are new and new 3in pipes.could there be something wrong with the cat causing the chirping sound. i checked everything and cant find a leak.
jeff
85' C10 350/700R4
2017 Chevy Tahoe
Old 10-18-2000, 07:51 PM   #12
fast71
Drive it like U stole it
fast71's Avatar
Post
I dont agree with Mike on the stock manifold gaskets . I have them on my 71 and thats the only thing that has stopped my headers from leaking . I have ran them on my nova for years with out having to replace them .
just my 2 cents.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 10-18-2000, 08:13 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Post
They might be leaking at a broken weld where the 4 pipes merge into the collector. I have a set like that. No way to fix it unless you take it apart, ie, cut it.
Chris Lucas
1973 Chevy C-10
1975 Chevy Silverado
Captkaos' Page
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-21-2000, 03:19 PM   #14
bigd65
bigd65's Avatar
Post
hey chris it almost sound s as if there is something loose inside the exhaust like maybe the cat coming apart or something is that possible. as i said it sounds like chirping and only hear it when i accelerate hard. if i just drive normal you really dont hear it. i gave up on it for awhile, got tired of R/R the header on that side so much.
jeff
85' C10 350/700R4
Angleton,TX>
2017 Chevy Tahoe
Old 10-31-2000, 01:38 PM   #15
bigd65
bigd65's Avatar
Post
found the leak it was on the passenger side. not sure if it was a leak or not. these headers had holes where the air pump injectors were and i ground down the driverside awhile back.well yesterday i finally ground down the one one the passenger side and now it quit making the noise. BTW i had to grind down the inside of the tube where the plugs are.it sounds good now
jeff
85' C10 350/700R4
Angleton,TX>
2017 Chevy Tahoe
