Old 02-10-2003, 11:44 PM   #1
Nelson
Question Cyl Head Question
On the intake side of the heads there are 4 larger square holes for Intake, But what is the small square holes for? There is 3, one on each end , and one in the middle And why does the middle one get carbon up?
o OO o OO o <--intake.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 02-10-2003, 11:49 PM   #2
crazy longhorn
Fabricate till you "puke"
The end holes are coolant passages, & the center holes are for heat under the carb(from exhaust passages)....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
