20" tire size
I think I know the answer to this, but want to run it by some people.
I'll be ordering my wheels here real shortly (probably tomorrow). I'm going to be running 20x10" with 6" backspacing and 315/35/20 in the back(tubbed rear wheel wells). I did all the measurements, and they should fit. Here is the question. What size in the front, on 20x8 wheels (4" backspacking). I'm thinking 245/45/20. Does this sound right, and should I have any fitment issues? The truck is bagged on stock arms, but I'll won't be driving it around all aired out. |
Re: 20" tire size
on my 86, I run 20x8.5- 4.25 BS w/ 245/40/20 up front, could have went with 45's no problem.
Mine's static dropped 5" up front. What wheels are you getting?
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
Re: 20" tire size
Oh, the wheels are 8.5" wide; raceline speedsters
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 20" tire size
Nice looking wheels...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: 20" tire size
245/40's to compliment the 315/35's. The 245/45's will have a taller 'looking' sidewall (they calculate out as the same dimension but the 45 series will appear taller).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-25-2008 at 01:09 PM. |
Re: 20" tire size
I got the wheels ordered today.
I ended up getting 5.75" backspacing on the rears, so the lip will match that of the fronts. Toyo discontinued the Proxes S/T tires (at least in 315/35/20), so the only other tire the guy could find me was some yokohamas that were about $500 for the package. However, Toyo is going to be coming out with 315/35/20s in the Proxes S/T IIs in September. The wheels are supposed to take 4-8 weeks to get made, so hopefully by then the Toyo tires will be out, and I can get the less expensive tires. Oh, the guy couldn't find a 245/40/20 tire either, so I'll probably go with 245/45/20 anyway. I guess we'll see in a few weeks. |
Re: 20" tire size
Those wheels look awesome
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Built 4 Speed
Re: 20" tire size
right now im running 20x 8.5 rims 5.5backspacing (were some of the early 20s to come out) and i am running general grabber 275 45 r20s all around i have no problems aside from a wee bit of rear inside fender rubbing on hard (40+) turns.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
Re: 20" tire size
Now I'm thinking of going with 275/40/20 for the front. Do the front tires rub on turns? How much are you lowered?
#10 | |
Built 4 Speed
Re: 20" tire size
just so you know a 45 is the tire i think Dodges 20" stock size. making tire variety alot larger and Cheaper. when i was looking at 40's they were all about 300 bucks.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 08-03-2008 at 04:46 PM. |
Re: 20" tire size
hey d10s69c10 ... are you running the Grabber UHP?
Built 4 Speed
Re: 20" tire size
sure am.
Re: 20" tire size
thank you ... i have seen those on tirerack.com but was unsure about the tread pattern ...
Built 4 Speed
Re: 20" tire size
theres the tread.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 08-04-2008 at 03:36 PM. |
